| » Frigidaire gas wall oven- burner won't stay lit |
Hey Bob, i was able to successfully test the amp draw of my ignitor and compared that to the broiler, it was significantly lower, i found a site that sells replacement parts at a really good discount, my ignitor happened to price out at $190.... !!! i took the chance to order from the site i found, i rec'd the parts today and will give the swap out a shot and let you know.
Todd keller |
Bob,
i replaced the ignitor today in my wall oven, that was the problem, just like everyone says, 90% of the time it is the ignitor. I got my replacement part from stoveparts.net,here's a link Igniters: Stoveparts there is a cross reference page to make sure you are getting a proper replacement. hope this helps you out. let me know if you want to contact me directly via email for more information. Todd |
Todd, Thanks for the info. I need to get an amp meter to check the draw. In the mean time I disassembled the burner and blew out the brass jet. After that the oven started working properly. It could also be that I moved the igniter in the process. I will check it with an amp meter if it fails again. Bob
Just a follow-up for anyone with this problem. I replaced the igniter and that fixed the problem. The igniter also controls the gas flow valve. The part was $135. As a precaution I will not be using the self-cleaning function. I never liked the idea of super-heating the oven to 900 - 1000 degrees just to clean it. In my opinion this will surely shorten the life of a residential oven. The igniter is right there in the oven getting blasted with 1000 degree heat during a self-cleaning cycle. I could be wrong but let's face the facts.....manufacturers don't want these appliances to last forever.
| Display Modes | |
| Frigidaire wall oven, burner goes out | BobMayo | Oven Repair (including Ranges and Cooktops) | 1 | 07-13-2011 07:35 AM |
| GE Wall Oven Won't Stay On | avallea | Oven Repair (including Ranges and Cooktops) | 0 | 04-28-2011 09:36 AM |
| JennAir wall oven burner issue | sszuba | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2010 03:15 AM |
| Oven gets to temp, but won't stay there, unless a top burner is on too. | bugaiho | Oven Repair (including Ranges and Cooktops) | 1 | 05-26-2009 07:51 PM |
| GE wall oven door won't stay fully closed | alfybill | Oven Repair (including Ranges and Cooktops) | 1 | 11-10-2008 04:12 PM |
