Discuss
Whirlpool Double Oven Control Board Replacement
 in
Looks like Whirlpool double oven control panel goes dead just about 5-7 year mark. The control board is the only
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Oven Control Board Replacement
  #1 (permalink)
Old 07-18-2011, 09:10 AM
Junior Member
destan is on a distinguished road
Default Whirlpool Double Oven Control Board Replacement
Brand: Whirlpool   Age: 5 - 10 years
The control board is the only electronic part in this oven. The telltale sign that the board is gone: dimmed or blank LED clock. It will start dimming and will go out totally in a day or two. It may come back for a brief period, but the ovens can not be used. The inside light will come on as you open the door, few buttons may make a beeping sound.
Go ahead and order the part. It is around $191.
Step by step:
You may want to get manual 8178007 that will give you a general idea.
1- Make sure the power is off. There is 240 volts inside, that will be lethal.
2- Open both doors.
3- Remove 4 screws on the side trim, 2 on each side, one inside the upper and 1 inside the lower oven.
4- Close oven doors.
5- Pull out the trim pieces at the bottom 1-2" towards you, then pull them down. Be carefull, the trim pieces are stainless and have sharp edges.
6- There are two types of controls. The older type: you will remove two screws that are on on the control panel, one on each side, normally hidden by the trim pieces. You will undo those, then tilt up the whole control panel at the bottom and unhook from the top. Then you will see a bundle of wires. Then go to Step 8.
7- For the newer type ovens. Those two screws have no function. If you pull the panel hard, you may break the tabs of the front bezel. A $60 part. The control panel will not tilt up from the bottom. You will then have to move the whole oven out. The trim pieces should have uncovered 4 to 6 more screws that fix the oven to the wood cabinet. Undo those screws. All you need is about 1" or so. You do not need to remove the screws. Then slide the whole oven out about 1" towards yourself. At the top, and the sides; you will see two black screws on each side. Remove the screws. Now lift up the conrol panel and tilt down to see a bundle of wires.
8- Next unhook all the wires. The only wires you need to worry about are 4 power wires that bring power in, red in color. Mark where they are connected. The rest are indexed and you can not mix them.
9- Take the panel out completely.
10- On the left you will see a small circuit board. This board controls the door lock when the oven is in self clean mode. You will need this board. Save it.
11- Then disconnect the ribbon cable. You need to pinch the two long sides and pull out the ribbon clip.
12- Then remove the 4 screws that hold the control board to the rest.
13- Put the new board in.
14- Put the door lock circuit board in it's slot.
15- Remove the ribbon cable clip from the socket of the new board, slide the clip up the ribbon cable. Insert the ribbon cable into the socket, Then click in the clip.
16- Go back to the oven, put all the cables back to their slots.
17- Follow the reverse steps.
18- Set the circuit breaker back on.
You should be ready to go. Remember the new board is static electricty sensitive, so I wore a wrist strap just to be sure. It is a $5 part.
The whole thing took me about 1 hour.
Hope this helps.
Ads By Google
  #2 (permalink)
Old 08-04-2011, 05:46 PM
Junior Member
billyd48359 is on a distinguished road
Default Fantastic help!
Destan,
Your explanation of how to replace the control panel on a Whirlpool Double Oven was fantastic. I was able to easily get my control panel replaced on my own in about an hour. Whirlpool was no help at all, so thank heavens for your posting. I owe you a beer!!!
Bill
  #3 (permalink)
Old 06-29-2012, 10:21 AM
Junior Member
deadcandance is on a distinguished road
Default Maytag/ Whirlpool Gemini Double Oven
Whirlpool customer service is one of the worst I have encountered. They consider a 6-7 year old $1500.00 Range to be considered OLD!!! I said to her wow! If the population was to throw their Whirlpool appliances into the landfills after 7 years , this would be quite a horrendous situation. I think it's disgusting for a company to build appliances with a shelf life of 6 - 7 years and with only a 1 year warranty!!! What a horrible brand! I will never buy another Whirlpool brand product ever again. You spend $1500.00 on a range oven and than around 5 - 7 years the control board blows out and costs another $500.00 to replace plus a service agents fee to remove and install. I asked the Whirlpool agent if I could get the Control board discounted and she refused and said I am sorry we are unable to help you. Pathetic! Their cost on these boards is around $120.00 or so I was told by a appliance Service rep... they could discount that $500.00 board even half and still make a decent profit.
DO NOT EVER BUY WHIRLPOOL. Go with other brands instead..... Their customer service policies are horrible. Your hard earned money will be buying an appliance with a 6 - 7 year shelf life before major repairs.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control Board Problems - Whirlpool Double Ovens PABLO919 Oven Repair (including Ranges and Cooktops) 0 11-26-2010 08:31 PM
Double oven control board repairjon1 Oven Repair (including Ranges and Cooktops) 0 10-12-2010 03:39 PM
whirlpool double oven control board burnt out? nevadamike Oven Repair (including Ranges and Cooktops) 0 12-25-2009 05:25 PM
whirlpool control board replacement BarryT Oven Repair (including Ranges and Cooktops) 0 09-08-2009 09:05 AM
blown control board on double wall oven lancea Oven Repair (including Ranges and Cooktops) 19 04-02-2009 02:28 PM
