Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Toggle Switch AP2024601 Replacement (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/267819-toggle-switch-ap2024601-replacement.html)
dliedeker 07-18-2011 08:43 AM
Hi, I found part # AP2024601
which my client says we shorted out with water. It is the oven light toggle switch on the control panel.
I have asked him to ensure the bulb is not burned out by opening the oven and ensuring the light comes on. I presume that (since there is a door toggle switch) the light will still come on if indeed the control panel toggle switch is shorted out. Am I correct?
If it turns out the bulb works, I plan to order part #AP2024601 - the toggle switch. It appears I can just use a flathead to "pop off" the old one without opening up the control panel. Is it this easy? Or do I need to take anything apart? Hoping to complete this (simple?) repair without damaging my client's stove further. Thanks in advance for your help.
Drew
