Discuss
Dacor Oven / Pure convection mode
 in
The pure convection mode doesn't reach the desired temp. The fan runs but it only heats up to about
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dacor Oven / Pure convection mode
  #1 (permalink)
Old 11-20-2007, 10:58 AM
GOP GOP is offline
Junior Member
GOP is on a distinguished road
Default Dacor Oven / Pure convection mode
Model Number: PCS130R   Brand: Dacor   Age: 5 - 10 years
The pure convection mode doesn't reach the desired temp. The fan runs but it only heats up to about 130 deg. I'm looking for some tips to determine if it's the convection element or if there is a separate thermostate for the convection mode. There are no error codes and it seems to work ok in the normal bake mode.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-20-2007, 04:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does the the oven work in the Bake mode?
If it does not, then the hi limit thermostat has to be reset.
If it does, then pull the convection heating element out as far as the wires go, disconnect one of the wires from the terminal on the heating element and check for 120V between each wire and the ground with the Convection mode on.
If the power on one of the legs is missing, replace the relay board.
- The part number for the relay board AP3851203
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-20-2007, 04:59 PM
GOP GOP is offline
Junior Member
Default
the oven works in bake mode but I've now created another problem in removing the oven the control panel came off. four of the five wires came out of the plug. the plug is numbered 1-8 and i have one white wire in #8
the loose wires are brown, yellow orange and white. I also get an F4 error code (open circut oven temp circut) can you tell me what wire goes where
  #4 (permalink)
Old 11-20-2007, 06:25 PM
GOP GOP is offline
Junior Member
Default
I found the info for the wire locations. Thanks to all who might have been doing any research
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dacor Oven won't heat devorahbee Oven Repair (including Ranges and Cooktops) 1 05-24-2008 10:56 PM
Convection Oven not heating well russ hibbeler Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:17 PM
Dacor lower oven not heating innovatech Oven Repair (including Ranges and Cooktops) 0 10-25-2007 10:44 AM
Caloric Convection Oven caloricgold Oven Repair (including Ranges and Cooktops) 0 09-03-2007 07:45 PM
Convection Oven wedofood Oven Repair (including Ranges and Cooktops) 0 08-14-2007 01:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
