Discuss
GE Hotpoint Oven pilot trouble.
 in
Hi, I just moved into a home with a GE Hotpoint gas oven/range. Shortly after I moved in, the oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Hotpoint Oven pilot trouble.
  #1 (permalink)
Old 07-17-2011, 03:43 PM
Junior Member
brian816 is on a distinguished road
Default GE Hotpoint Oven pilot trouble.
Model Number: RGB508PEA4WH   Brand: GE   Age: More than 10 years
I just moved into a home with a GE Hotpoint gas oven/range. Shortly after I moved in, the oven stopped working. I remember seeing a pilot flame underneath the oven floor, towards the back and slightly on the left hand side. I opened the broiler, and the flame went out. The oven has an electric heating element on the side of the gas bar, under the oven floor. The heating element still works. If I turn the oven on, and hold the dial in for a few seconds, the heating element will heat, and the gas bar will ignite. However, there appears to be no heat regulation, and the entire flame is much less intense than what is was before. If I then turn off the oven, the flame stay ingited for a few seconds, then extinguishes. I saw a diagram that showed how to light the pilot light (on a seemingly similar model), but I can't get it lit.
Any help would be appreciated.
Ads By Google
Related Models
General Electric RGB508PEA4WH Gas range
General Electric RGB508PEA5AD Gas range
General Electric RGB508PEA5WH Gas range
General Electric RGB508PEA6WH Gas range
General Electric RGB508PEH1CT Gas range
General Electric RGB508PEH1WH Gas range
General Electric RGB508PEH2CT Gas range
General Electric RGB508PEH2WH Gas range
General Electric RGB508PEH3CT Gas range
General Electric RGB508PEH3WH Gas range
General Electric RGB508PPA1AD Gas range
General Electric RGB508PPA1WH Gas range
General Electric RGB508PPA2AD Gas range
General Electric RGB508PPA2WH Gas range
General Electric RGB508PPA3AD Gas range
General Electric RGB508PPA3WH Gas range
General Electric RGB508PPA4AD Gas range
General Electric RGB508PPA4WH Gas range
General Electric RGB508PPA5AD Gas range
General Electric RGB508PPA5WH Gas range
General Electric RGB508PPH1AD Gas range
General Electric RGB508PPH1CT Gas range
General Electric RGB508PPH1WH Gas range
General Electric RGB508PPH2AD Gas range
General Electric RGB508PPH2WH Gas range
General Electric RGB508PS1 Gas range
General Electric RGB508PS2 Gas range
General Electric RGB508PT1AD Gas range
General Electric RGB508PT1WH Gas range
General Electric RGB508PT2AD Gas range
General Electric RGB508PT2WH Gas range
General Electric RGB508PT3AD Gas range
General Electric RGB508PT3WH Gas range
General Electric RGB523PPH1CT Gas range
General Electric RGB523PPH1WH Gas range
General Electric RGB523PPH2CT Gas range
General Electric RGB523PPH2WH Gas range
General Electric RGB5241F0 Gas range
General Electric RGB5241F1 Gas range
General Electric RGB524EH1 Electric range
General Electric RGB524EJ1 Gas range
General Electric RGB524EJ2 Gas range
General Electric RGB524EJ3 Gas range
General Electric RGB524EN1 Gas range
General Electric RGB524ER1 Gas range
General Electric RGB524ER2 Gas range
General Electric RGB524ER3 Gas range
General Electric RGB524ER4 Gas range
General Electric RGB524ET1AD Gas range
General Electric RGB524ET1WH Gas range
General Electric RGB524EV1AD Gas range
General Electric RGB524EV1WH Gas range
General Electric RGB524EV2AD Gas range
General Electric RGB524EV2WH Gas range
General Electric RGB524EV3AD Gas range
General Electric RGB524EV3WH Gas range
General Electric RGB524EV4AD Gas range
General Electric RGB524EV4WH Gas range
General Electric RGB524EV5AD Gas range
General Electric RGB524EV5WH Gas range
General Electric RGB524F0 Gas range
General Electric RGB524F1 Gas range
General Electric RGB524GES1 Gas range
General Electric RGB524GES2 Gas range
General Electric RGB524GPS1 Gas range
General Electric RGB524GPS2 Gas range
General Electric RGB524PEA1AD Gas range
General Electric RGB524PEA1WH Gas range
General Electric RGB524PEA2AD Gas range
General Electric RGB524PEA2CT Gas range
General Electric RGB524PEA2WH Gas range
General Electric RGB524PEA3AD Gas range
General Electric RGB524PEA3WH Gas range
General Electric RGB524PEA4AD Gas range
General Electric RGB524PEA4WH Gas range
General Electric RGB524PEA5AD Gas range
General Electric RGB524PEA5WH Gas range
General Electric RGB524PEA6WH Gas range
General Electric RGB524PEH1CT Gas range
General Electric RGB524PEH1WH Gas range
General Electric RGB524PEH2CT Gas range
General Electric RGB524PEH2WH Gas range
General Electric RGB524PEH3CT Gas range
General Electric RGB524PEH3WH Gas range
General Electric RGB524PH1 Gas range
General Electric RGB524PJ1 Gas range
General Electric RGB524PJ2 Gas range
General Electric RGB524PJ3 Gas range
General Electric RGB524PN1 Gas range
General Electric RGB524PPA1AD Gas range
General Electric RGB524PPA1WH Gas range
General Electric RGB524PPA2AD Gas range
General Electric RGB524PPA2CT Gas range
General Electric RGB524PPA2WH Gas range
General Electric RGB524PPA3AD Gas range
General Electric RGB524PPA3WH Gas range
General Electric RGB524PPA4AD Gas range
General Electric RGB524PPA4WH Gas range
General Electric RGB524PPA5WH Gas range
General Electric RGB524PPH1CT Gas range
General Electric RGB524PPH1WH Gas range
General Electric RGB524PPH2CT Gas range
General Electric RGB524PPH2WH Gas range
General Electric RGB524PR1 Gas range
General Electric RGB524PR2 Gas range
General Electric RGB524PR3 Gas range
General Electric RGB524PT1AD Gas range
General Electric RGB524PT1WH Gas range
General Electric RGB524PV1AD Gas range
General Electric RGB524PV1WH Gas range
General Electric RGB524PV2AD Gas range
General Electric RGB524PV2WH Gas range
General Electric RGB524PV3AD Gas range
General Electric RGB524PV3WH Gas range
General Electric RGB524PV4AD Gas range
General Electric RGB524PV4WH Gas range
General Electric RGB525ES1 Gas range
General Electric RGB525ET1WW Gas range
General Electric RGB525ET2WW Gas range
General Electric RGB525ET3WW Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Hotpoint Oven pilot trouble. brian816 Oven Repair (including Ranges and Cooktops) 0 07-17-2011 03:36 PM
Can not get Oven to light, pilot ok Barbarian Oven Repair (including Ranges and Cooktops) 0 10-02-2010 12:37 PM
Trouble with Pilot GregInJersey Oven Repair (including Ranges and Cooktops) 2 07-03-2009 08:17 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 05:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 04:30 PM
