Simmer select infinite switch (part #316049800) would not turn off front burner: I order a replacement switch (an Electrolux part) and have installed it. Burner will not work. Switch is not identical to the original Kenmore part. If I reverse the wires (one of which leads to indication light) the simmer select light and the indicator light flicker on and off.
Thanks. I have it right, finally. Jollyboat
