| » Kenmore Range flat top burner stays on high |
Model Number: 665.92023101 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore flat top oven model 665.92023101. The element on light was stuck on so I replaced the infinite switch. The switch didn't solve the problem so I looked at the heating element and noticed a connector had come loose. I reconnected it and the light went off. The problem I have now is whenever I turn that burner on, it is always on high heat regardless of where the dial is set. Any ideas?
| Display Modes | |
| front right burner stays on high | rvh | Oven Repair (including Ranges and Cooktops) | 3 | 04-12-2011 05:01 PM |
| Tappan electric range burner- stays on high | susanherna | Oven Repair (including Ranges and Cooktops) | 0 | 03-09-2011 09:26 AM |
| Burner stays on high setting. | billheider | Oven Repair (including Ranges and Cooktops) | 0 | 01-26-2010 09:25 AM |
| 6/9 flat top burner always on "high" | Andrew G | Oven Repair (including Ranges and Cooktops) | 0 | 08-19-2009 06:43 PM |
| GE Cooktop Burner Can't regulate temp, only stays on high | ecelebration | Oven Repair (including Ranges and Cooktops) | 1 | 01-05-2009 04:26 AM |
