Discuss
Oven will not light
 in
Oven will not light replaced igniter.Igniter will not glow.There is 120 volts coming down to the safety valve. With igniter
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not light
  #1 (permalink)
Old 07-16-2011, 06:11 AM
Junior Member
C Dale is on a distinguished road
Default Oven will not light
Model Number: RGB528GET1WH   Brand: Hotpoint   Age: 5 - 10 years
Oven will not light replaced igniter.Igniter will not glow.There is 120 volts coming down to the safety valve. With igniter hooked up there is 4.6v on igniter side and igniter still will not glow. Is the safety valve bad?
Ads By Google
Related Models
General Electric RGB528GET1WH Gas range
General Electric RGB528GET2AD Gas range
General Electric RGB528GET2WH Gas range
General Electric RGB528GEV1AD Gas range
General Electric RGB528GEV1WH Gas range
General Electric RGB528GEV2AD Gas range
General Electric RGB528GEV2WH Gas range
General Electric RGB528GEV3AD Gas range
General Electric RGB528GEV3WH Gas range
General Electric RGB528GF0 Gas range
General Electric RGB528GF1 Gas range
General Electric RGB528GPH1 Gas range
General Electric RGB528GPJ1 Gas range
General Electric RGB528GPJ2 Gas range
General Electric RGB528GPJ3 Gas range
General Electric RGB528PEA1WW Gas range
General Electric RGB528PEA2WW Gas range
General Electric RGB528PEA5WW Gas range
General Electric RGB528PEH1WW Gas range
General Electric RGB528PEH2WW Gas range
General Electric RGB528PH1 Gas range
General Electric RGB528PJ1 Gas range
General Electric RGB528PJ2 Gas range
General Electric RGB528PJ3 Gas range
General Electric RGB529GEP1 Gas range
General Electric RGB529GEP2 Gas range
General Electric RGB529GEP3 Gas range
General Electric RGB529GEP4 Gas range
General Electric RGB530BEA1AD Gas range
General Electric RGB530BEA1WH Gas range
General Electric RGB530BEA2AD Gas range
General Electric RGB530BEA2WH Gas range
General Electric RGB530BEA3AD Gas range
General Electric RGB530BEA3WH Gas range
General Electric RGB530BEW1AD Gas range
General Electric RGB530BEW1WH Gas range
General Electric RGB530BEW2AD Gas range
General Electric RGB530BEW2WH Gas range
General Electric RGB530BEW3AD Gas range
General Electric RGB530BEW3WH Gas range
General Electric RGB532BEA1AD Gas range
General Electric RGB532BEA1CT Gas range
General Electric RGB532BEA1WH Gas range
General Electric RGB532BEA2AD Gas range
General Electric RGB532BEA2CT Gas range
General Electric RGB532BEA2WH Gas range
General Electric RGB532BEA3CT Gas range
General Electric RGB532BEA4AD Gas range
General Electric RGB532BEA4CT Gas range
General Electric RGB532BEA4WH Gas range
General Electric RGB532BEA5AD Gas range
General Electric RGB532BEA5WH Gas range
General Electric RGB532BEA6WH Gas range
General Electric RGB532BEA7WH Gas range
General Electric RGB532BEA8WH Gas range
General Electric RGB532BEW1AD Gas range
General Electric RGB532BEW1WH Gas range
General Electric RGB532BEW2AD Gas range
General Electric RGB532BEW2WH Gas range
General Electric RGB532BEW3AD Gas range
General Electric RGB532BEW3WH Gas range
General Electric RGB532ET1AD Gas range
General Electric RGB532ET1WH Gas range
General Electric RGB532ET2AD Gas range
General Electric RGB532ET2WH Gas range
General Electric RGB532EV1AD Gas range
General Electric RGB532EV1WH Gas range
General Electric RGB532EV2AD Gas range
General Electric RGB532EV2WH Gas range
General Electric RGB533BEK1BB Gas range
General Electric RGB533BEK2BB Gas range
General Electric RGB533CEH1CC Gas range
General Electric RGB533CEH2CC Gas range
General Electric RGB533CEH3CC Gas range
General Electric RGB533CEH4CC Gas range
General Electric RGB533CEH5CC Gas range
General Electric RGB533ET1WW Gas range
General Electric RGB533ET2WW Gas range
General Electric RGB533EV2WW Gas range
General Electric RGB533WEA1WW Gas range
General Electric RGB533WEA2WW Gas range
General Electric RGB533WEA4WW Gas range
General Electric RGB533WEA5WW Gas range
General Electric RGB533WEA6WW Gas range
General Electric RGB533WEA7WW Gas range
General Electric RGB533WEA8WW Gas range
General Electric RGB533WEH1WW Gas range
General Electric RGB533WEH2WW Gas range
General Electric RGB533WEH3WW Gas range
General Electric RGB533WEH4WW Gas range
General Electric RGB533WEH5WW Gas range
General Electric RGB533WEW1WW Gas range
General Electric RGB533WEW2WW Gas range
General Electric RGB533WEW3WW Gas range
General Electric RGB535BEA1AD Gas range
General Electric RGB535BEA1CT Gas range
General Electric RGB535BEA1WH Gas range
General Electric RGB535BEA2AD Gas range
General Electric RGB535BEA2CT Gas range
General Electric RGB535BEA2WH Gas range
General Electric RGB535BEA3CT Gas range
General Electric RGB535BEA4AD Gas range
General Electric RGB535BEA4CT Gas range
General Electric RGB535BEA4WH Gas range
General Electric RGB535BEA5AD Gas range
General Electric RGB535BEA5WH Gas range
General Electric RGB535BEA6WH Gas range
General Electric RGB535BEA7WH Gas range
General Electric RGB535BEA8WH Gas range
General Electric RGB535GET1AD Gas range
General Electric RGB535GET1WH Gas range
General Electric RGB535GET2AD Gas range
General Electric RGB535GET2WH Gas range
General Electric RGB535GEV1AD Gas range
General Electric RGB535GEV1WH Gas range
General Electric RGB535GEV2AD Gas range
General Electric RGB535GEV2WH Gas range
General Electric RGB535GEV3AD Gas range
General Electric RGB535GEV3WH Gas range
General Electric RGB535GEV4AD Gas range
  #2 (permalink)
Old 07-16-2011, 06:15 AM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 4 01-30-2011 08:26 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 1 02-05-2010 01:07 PM
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Oven doesn't light, Broil and Preheat will light tisears Oven Repair (including Ranges and Cooktops) 1 09-09-2009 12:38 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
