Frigidaire oven : F10 code frequently flashes and beeps it works on some temperatures but not on others tempermental reset by killing power often it is after cooking it will still beep when cooling down what part needs to be replaced is it temperature probe in oven or major control panel.
Hello kwilsonp. Based on the code you provided, it sounds like the temperature sensor is bad and will need to be replaced. First test the sensor. It should read around 1100 ohms at room temperature and around 1650 ohms at 350°. If it checks bad, you will need to replace the sensor. Hope this helps. Part number: AP3363354
