Hello,
I have a GE Model JGBS20 gas range.
My problem is with the oven. It works fine except that from time to time, the oven will come on for about 10 seconds then shut off again. It does this often, but not at regular intervals. It varies.
Let me know if this is an easy fix or if I should just invest in a new range.
