Discuss
possible membrane issue?
 in
New to the forum, but I love how active this place is I have a Whirlpool GY397LXUB 0 and most
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » possible membrane issue?
  #1 (permalink)
Old 07-14-2011, 10:03 PM
Junior Member
NisAznMonk is on a distinguished road
Default possible membrane issue?
Model Number: GY397LXUB 0   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool GY397LXUB 0 and most of the buttons do not work. The only ones that seem to work are the 1, 6, 7, 9 and cancel buttons. On the left side the BAKE button doesn't seem to work, but I don't know if that is because of the number pad or not.
All of the burners work VERY well though.
Do I need to replace the control pad or just the membrane? Which one and i supposed to buy, and are there any special instructions on how to install it? This is what I have found after doing a quick search:
Quote:
First turn off circuit breaker to stove. Slide the stove out about 4 inches from the counter to expose the two phillips head screws, one on the left side and one on the right side of touch panel. Take out screws. Then take out four Phillip head screws on the bottom side of panel, this will set panel loose from stove. Carefully pull up touch pad (switch membrane) from control panel; it is sticky glued in place. Disconnect ribbon cables on switch membrane from control panel by depressing cable locks while pulling firmly. Remove switch membrane. Clean area before installing new membrane. Reassemble turn on power and you are done.
Do I need any special cleaning solution or is it simply pop out the old one and reinsert the new one?
If it isn't the membrane what else should i do?
Thanks.
Ads By Google
Related Models
Whirlpool GY398LXPB00 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPB01 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPB02 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPB03 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPB04 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPQ00 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPQ01 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPQ02 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPQ03 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPQ04 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPS00 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPS01 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPS02 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPS03 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPS04 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPT00 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPT01 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPT02 30" Slide - in Electric Oven Self Clean
International GZ2626GEKB Ref - SXS/I&W
International GZ2626GEKS Ref - SXS/I&W
International GZ2626GEKW Ref - SXS/I&W
International GZ2727GEHB Ref - SXS/I&W
International GZ2727GEHQ Ref - SXS/I&W
International GZ2727GEHW Ref - SXS/I&W
Whirlpool GZ5730XLB0
Whirlpool GZ5730XLQ0
Whirlpool GZ5730XLS0
Whirlpool GZ5730XLT0
Whirlpool GZ5730XRB0
Whirlpool GZ5730XRB1
Whirlpool GZ5730XRQ0
Whirlpool GZ5730XRQ1
Whirlpool GZ5730XRS0
Whirlpool GZ5730XRS1
Whirlpool GZ5730XRT0
Whirlpool GZ5730XRT1
Whirlpool GZ5736XLB0
Whirlpool GZ5736XLQ0
Whirlpool GZ5736XLS0
Whirlpool GZ5736XLT0
Whirlpool GZ5736XRB0
Whirlpool GZ5736XRB1
Whirlpool GZ5736XRQ0
Whirlpool GZ5736XRQ1
Whirlpool GZ5736XRS0
Whirlpool GZ5736XRS1
Whirlpool GZ5736XRT0
Whirlpool GZ5736XRT1
Whirlpool GZ7730XGS0
Whirlpool GZ7730XGS1 30" Range Hood (use with Gas or Electric Range)
Whirlpool GZ7736XGS0
Whirlpool GZ7736XGS1 30" Range Hood (use with Gas or Electric Range)
Whirlpool GZ7930XGS0
Whirlpool GZ7930XHS0
Whirlpool GZ7930XHS1 30" and 36" Retractable Down Draft Vent System (internal Venting)
Whirlpool GZ7936XGS0
Whirlpool GZ7936XHS0
Whirlpool GZ7936XHS1 30" and 36" Retractable Down Draft Vent System (internal Venting)
Whirlpool GZ8330XLS0 30" & 36" Range Hood (vented) (use with Gas or E
Whirlpool GZ8330XLS1 30" & 36" Range
Whirlpool GZ8336XLS0 30" & 36" Range Hood (vented) (use with Gas or E
Whirlpool GZ8336XLS1 30" & 36" Range
Bosch GZ900-060
Bosch GZ936-010
Whirlpool GZ9730SSS0 30" & 36" Hood
Whirlpool GZ9730XSS0 30" & 36" Hood
Whirlpool GZ9736SSS0 30" & 36" Hood
Whirlpool GZ9736XSS0 30" & 36" Hood
Bosch GZ990-010
Bosch GZ991-010
Bosch GZ992-010
Hardwick H-414 Surface Unit - Gas
Hardwick H-434 Surface Unit - Gas
Hardwick H-444 Surface Unit - Gas
Hardwick H-445 Surface Unit - Ele
Hardwick H-446 Surface Unit - Gas
Thermador H-62
Thermador H-62A
Thermador H-63
Thermador H-63A
Thermador H-64
Thermador H-65
Thermador H-66
Thermador H-66A
Thermador H-67
Thermador H-67A
Thermador H-71
Thermador H-76
Thermador H-98
Hoover H1005---
Hardwick H1100PAW Range - F/s Std Gas
Hardwick H1100PRA Range - F/s Std Gas
Hardwick H1100PRA-K Range - F/s Std Gas
Hardwick H1100PRW Range - F/s Std Gas
Hardwick H1100PRW-K Range - F/s Std Gas
Hardwick H1500PRA Range - F/s Std Ele
Hardwick H1500PRW Range - F/s Std Ele
Frigidaire H15A Frg(v1) / Chest Freezer
Frigidaire H15B Frg(v2) / Chest Freezer
Frigidaire H15C Frg(v3) / Chest Freezer
Frigidaire H20A Frg(v1) / Chest Freezer
Frigidaire H20B Frg(v2) / Chest Freezer
Frigidaire H23A Frg(v1) / Chest Freezer
Frigidaire H23B Frg(v2) / Chest Freezer
Hoover H2510
Hoover H2800--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H2800050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H28010RM Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover H2850 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H2850050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000001 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000006 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000011 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H30010RM Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3010--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3010020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3012020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Maytag H302RA Hood
  #2 (permalink)
Old 07-15-2011, 07:14 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Thanks.
Monk,
I'm sure a new membrane assembly, will solve your issue.
Part number: AP4423195
Something you want to remember about keypads and membrane panels, No household Cleaning Solutions, just a damp cloth.
Here's some help:
1. Turn off the electrical power to the range.
2. Remove the knobs from the controls.
3. Unsnap the two clips at the inner control
locations and lift the front edge of the
control panel glass, then slide the top
edge of the glass out of the control panel
flange, and remove it.
4.
To remove the electronic oven control:
a) Remove the two screws from the bezel
and window and remove them from
the control panel.
b) Remove the two screws from the
bracket, lift the electronic oven control
assembly off the control panel, and rotate
it back so you can access the connectors.
c) Disconnect the three connectors from
the electronic oven control.
5. To remove the control panel
a) Remove the two top screws and the
two side screws in the end caps from
the control panel.
b) Open the oven door and remove the
three bottom screws.
c) Remove the control panel from the
range by pulling it forward and lifting it
at the front.
d) To remove an end cap, remove the two
mounting screws (1 top & 1 bottom).
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Switch Membrane Hutton Oven Repair (including Ranges and Cooktops) 1 01-11-2010 04:28 PM
Switch Membrane Hutton Oven Repair (including Ranges and Cooktops) 1 01-11-2010 04:27 PM
Membrane switch Grensquell Oven Repair (including Ranges and Cooktops) 2 07-30-2009 07:36 AM
replace membrane gerald gerard Oven Repair (including Ranges and Cooktops) 0 06-26-2009 04:58 AM
replace membrane gerald gerard Oven Repair (including Ranges and Cooktops) 0 06-26-2009 04:56 AM
