| » Frigidaire won't lock door to clean |
Model Number: FES388WGCI Brand: Frigidaire Age: 5 - 10 years
The clean cycle starts on the keypad, but after 1 minute it starts to beep and says "door". We have checked that nothing is blocking the door, and the oven itself cooks just fine. But we can't get it to start cleaning!
Thanks Ads By Google Related Models |
Quote:
Can you hear the door latch motor run, when the oven is trying to lock ? Part number: AP3140265 That latch motor is mounted to the back of the range, you'll need to slide the range out and may need to remove the back panel to access it and the switches and wiring to check them for damaged wires or switches. That latch switch circuit is a, 24 hour a day, 7 day a week circuit, I'm pretty sure you'll find your issue in that area. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Baltzc,
Good Deal, Drop us a line, and let us know what you determine, and the needed repairs, for future refference. Good Luck,
__________________
| Display Modes | |
| Viking Oven Door Lock After Self Clean | bennettjon | Oven Repair (including Ranges and Cooktops) | 3 | 09-18-2011 11:50 AM |
| Kitchen Aid Self Clean Problem With Door Lock | Dexter Adderley | Oven Repair (including Ranges and Cooktops) | 0 | 11-06-2010 07:55 AM |
| self clean oven door will not lock | junklady | Oven Repair (including Ranges and Cooktops) | 1 | 11-04-2010 09:05 AM |
| Door Won't Lock To Self Clean - Code F5e1 | dtimmester | Oven Repair (including Ranges and Cooktops) | 0 | 01-25-2010 12:14 PM |
| Hinges and door lock during self clean | kerry1h | Oven Repair (including Ranges and Cooktops) | 0 | 09-13-2009 08:04 AM |
