Discuss
oven does not heat
 in
Oven does not heat, in order to cook at 300 degress you set the temp at 500. Was suggested by
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven does not heat
  #1 (permalink)
Old 07-14-2011, 01:01 PM
Junior Member
smedleybr is on a distinguished road
Default oven does not heat
Model Number: jmp28gor1ad   Brand: GE   Age: More than 10 years
Oven does not heat, in order to cook at 300 degress you set the temp at 500. Was suggested by representive that we needed an oven probe. Ordered a WB21X5301, sensor ASM. The assembly appears to be for a burner as it has a place for a knob...Need your return policy.
Ruby Smedley
Ads By Google
Related Models
General Electric JMP28GR1AD Electric range
General Electric JMP28GR1WH Electric range
General Electric JMP28GR2AD Electric range
General Electric JMP28GR2WH Electric range
General Electric JMP28GR3AD Electric range
General Electric JMP28GR3WH Electric range
General Electric JMP28GT1AD Electric range
General Electric JMP28GT1WH Electric range
General Electric JMP28GV1AD Electric range
General Electric JMP28GV1WH Electric range
General Electric JMP29GR1BK Electric range
General Electric JMP29GR2BK Electric range
General Electric JMP29GR3BK Electric range
General Electric JMP29GT1BB Electric range
General Electric JMP29GV1BB Electric range
General Electric JMP2SGR3WH ELECTRIC DROP IN RANGE
General Electric JMP31BL1BB Electric range
General Electric JMP31BL2BB ELECTRIC RANGE
General Electric JMP31CL1CC Electric range
General Electric JMP31CL2CC ELECTRIC RANGE
General Electric JMP31WA1WW Electric range
General Electric JMP31WA2WW Electric range
General Electric JMP31WC1WW Electric range
General Electric JMP31WC2WW Electric range
General Electric JMP31WC3WW ELECTRIC RANGE
General Electric JMP31WR1WH Electric range
General Electric JMP31WR2WH Electric range
General Electric JMP31WT1WW Electric range
General Electric JMP31WV1WW Electric range
General Electric JMP31WW1WW Electric range
General Electric JMP32AR1AG Electric range
Maytag JMRH2 JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH2A JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH36B COMMERCIAL COOKING
 JMRH36GT COMMERCIAL COOKING
Maytag JMRH4 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRH48GT COMMERCIAL COOKING
Maytag JMRH4A JADE MODULAR OPEN BURNER (COOKING GAS)
Maytag JMRH6 JADE MODULAR OPEN BURNER (COOKING GAS)
 JMRHE33 COMMERCIAL COOKING
General Electric JMS07*J1 Electric range
General Electric JMS07*J2 Electric range
General Electric JMS07*J3 Electric range
General Electric JMS07*J4 Electric range
General Electric JMS07*J5 Electric range
General Electric JMS070J3 ELECTRIC DROP-IN RANGES
General Electric JMS07G*P1 Electric range
General Electric JMS07J4 ELECTRIC DROP-IN RANGE
General Electric JMS07J5 27" DROP IN ELECTRIC RANGE
General Electric JMS08BA1AD Electric range
General Electric JMS08BA1WH Electric range
General Electric JMS08BA2AD Electric range
General Electric JMS08BA2WH Electric range
General Electric JMS08BD1AD Electric range
General Electric JMS08BD1WH Electric range
General Electric JMS08BD2CT Electric range
General Electric JMS08BD2WH Electric range
General Electric JMS08BD3CT Electric range
General Electric JMS08BD3WH Electric range
General Electric JMS08BW1AD Electric range
General Electric JMS08BW1WH Electric range
General Electric JMS08BW2AD Electric range
General Electric JMS08BW2WH Electric range
General Electric JMS08GR1AD Electric range
General Electric JMS08GR1WH Electric range
General Electric JMS08GR2AD Electric range
General Electric JMS08GR2WH Electric range
General Electric JMS08GT1AD Electric range
General Electric JMS08GT1WH Electric range
General Electric JMS08GV1AD Electric range
General Electric JMS08GV1WH Electric range
General Electric JMS10GR1AD Electric range
General Electric JMS10GR1WH Electric range
General Electric JMS10GR2AD Electric range
General Electric JMS10GR2WH Electric range
General Electric JMS27G*01 GE FREE-STANDING / DROP-
General Electric JMS27G*H1 Electric range
General Electric JMS27G*J1 Electric range
General Electric JMS27G*J2 Electric range
General Electric JMS27G*J3 Electric range
General Electric JMS27G*J4 Electric range
General Electric JMS27G0J3 ELECTRIC DROP-IN RANGE
General Electric JMS27GJ4 ELECTRIC DROP-IN RANGE
General Electric JMT10F01 Electric range
General Electric JMT11F01 Electric range
General Electric JMT1901 Electric range
General Electric JMT19F01 Electric range
General Electric JMT2001 Electric range
General Electric JMT20F01 Electric range
Jenn-Air JMV8000ADB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000ADW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8000BDW MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAB MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag JMV8100AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8166BAB MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8166BAW MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV8186AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAB14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAB16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8186AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAS14 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAS16 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8186AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV8186AAW15 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV8186AAW17 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Jenn-Air JMV8196AAB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAQ MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAS MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196AAW MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACB MWAVE- MOUNTED UNDER CABINET
Jenn-Air JMV8196ACQ MWAVE- MOUNTED UNDER CABINET
  #2 (permalink)
Old 07-14-2011, 01:45 PM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Hello smedleybr. You may have been sent the wrong part. Based on the part number you provided, it is the oven sensor. You can call us at 877-477-7278 and we will be glad to take care of you on this matter. Here is a link to our return policy as well. Here is a picture of the oven sensor part number you provided. Hope this helps.
Cancellations & Returns -- AppliancePartsPros.com
Part number: AP2023670
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't heat up to pre-heat setting tmilam Oven Repair (including Ranges and Cooktops) 0 04-24-2011 04:48 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 01:22 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
