| » Gas Oven Heats Up Too Slowly |
Model Number: SCG20200W Brand: Jenn-Air Age: 5 - 10 years
The gas oven takes way too long to heat up. There is also a smell of gas at times when the oven is turned on. This just started happening recently.
The broiler appears to work fine. The burners work fine as well. I removed the lower drawer and the cover panel behind it and located the Oven Valve. It appears that when the oven is on and I wiggle one of the electrical contacts on the Oven Valve I can hear more gas passing through the valve. Before purchasing the $100 part I want to be sure that this is the problem. Anyone experienced this and solved it successfully? Thanks. |
Most likely the problem with your oven is a bad igniter, not the gas valve.
You can learn how the oven igniter works from the one of previous posts here: Oven won't lite? - The part number for the oven igniter AP205873 - Here are the break down diagrams for the Jenn Air range Model SCG20200W Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Gene,
Thank you. Your assessment was spot on. The igniter was bad - cracked as a matter of fact. I replaced it with the one for the Broiler to make sure and the oven works. I will now order an igniter. Thanks again. |
| Display Modes | |
| Maytag dryer drying slowly | stodtmeister | Dryer Repair | 3 | 12-12-2007 06:12 PM |
| Dryer heats sometimes | TommyC | Dryer Repair | 1 | 10-27-2007 01:44 PM |
| Dryer Drum Turns Slowly | BETA270 | Dryer Repair | 4 | 10-24-2007 03:14 PM |
| Oven lights and heats to Temp but goes out immediately!! | jomo | Oven Repair (including Ranges and Cooktops) | 0 | 08-31-2007 10:49 AM |
| Washer will spin slowly but not drain | Mikie Martin | Washer Repair | 0 | 07-31-2007 08:36 AM |
