| » Ingiter |
Model Number: PH0203-UD Brand: Modern Maid Age: More than 10 years
I have a Modern Maid model ph0203-UD. Although the igniter glows; there is no gas coming. I don't see any thermocouple.
The broiler is woking fine which makes me think that the knob is ok. Could it be that the igniter is bad? Ads By Google Related Models |
Quote:
You're on the right track, It is most likely a weak oven burner igniter, Part number: 31939701 They can glow "red" but will not produce enough amp draw or voltage to the burner valve to open it and release the gas. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Good deal, I'm sure you'll be fine once you get the igniter replaced.
__________________
| Display Modes | |
| spark ingiter electrode replacement | jyan | Oven Repair (including Ranges and Cooktops) | 0 | 04-23-2009 12:02 PM |
| Oven ingiter will start gas then both shut off | bradk36 | Oven Repair (including Ranges and Cooktops) | 2 | 01-11-2009 09:14 AM |
