cavsfan
#1 Posted : Monday, July 11, 2011 3:15:20 PM(UTC)
cavsfan
My bake element fried. Replaced it with a new one. Now neither the bake element nor broil element work. Control panel appears to work, but neither heat. All four surface units work ok.
#2 Posted : Tuesday, July 12, 2011 12:59:03 AM(UTC)
Replacement parts for FRIGIDAIRE FEF375ESA Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441411en.pdf
Since you do not get an error and I am assuming the oven does not show it is ready then it sounds like the control board (Item 20 in Section 1) is toast.
I would unplug the unit and check the wires that go to the elements just to be sure that one of them has not burned out.
You may also want to check the temperature sensor.
Here is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
