| » Cooktop turns back on! |
Model Number: FEC30S6ASF Brand: Frigidaire Age: 1 - 5 years
I have a Frigidaire flat, ceramic, electric cooktop. The model number is FEC30S6ASF. One of the elements has developed a problem turning off. When the problem began, the element would occassionally only go to the highest setting, even if the knob was set to low. Then it began to have a problem turning off. When the know was turned to the off position, the element would turn off, only to click back on a few seconds later and continue at the highest heat setting. After turning it on and off a few times, it would finally turn off completely. Now it wont turn off and I have to turn off the breaker to get it to stop. When I turn the breaker back on, the element goes back on at high heat. What is the problem and do you have the part? Thanks for your help.
| Display Modes | |
| Gas Dryer won't heat and turns back on | bombersdryer | Dryer Repair | 0 | 11-21-2009 01:25 PM |
| remove old destroyed cooktop and install new cooktop | richlibl | Oven Repair (including Ranges and Cooktops) | 4 | 07-06-2009 10:42 PM |
| Whirlpool glass cooktop replacement for gas cooktop | ujohnston | Oven Repair (including Ranges and Cooktops) | 3 | 03-22-2009 01:39 PM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| having pronblem with puttin clip back on for top and back | robert mcwhirter | Washer Repair | 1 | 11-06-2008 07:08 AM |
