Discuss
Crosley Electric range F2 and F3 Fault Codes
 in
I am getting a Fault Code of F2 and F3 it shut my oven down in the middle of dinner!
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Crosley Electric range F2 and F3 Fault Codes
  #1 (permalink)
Old 03-13-2009, 06:11 PM
Junior Member
mzummallen is on a distinguished road
Default Crosley Electric range F2 and F3 Fault Codes
Brand: Crosley   Age: 5 - 10 years
  #2 (permalink)
Old 03-14-2009, 04:29 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Need a Model Number in order for someone to help you.
Model Number Locator
__________________
  #3 (permalink)
Old 03-14-2009, 05:26 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Unfortunantly those codes mean a clock control board and a sensor. The sensor is wired through the board. So you would most likely need the clock control board. But, if you are going to do the job, I would recommend replacing the sensor for another $45.00. Tom
  #4 (permalink)
Old 03-14-2009, 05:35 AM
Junior Member
Default code
ce6898vvv This is my model # should I get a professional for the timer board
  #5 (permalink)
Old 03-14-2009, 05:39 AM
Junior Member
Default
  #6 (permalink)
Old 03-14-2009, 08:25 AM
Senior Expert
APP Volunteer
Default
Here is the error codes
F2 - Oven to Hot - Replace relay board (if present) or bad oven temperature sensor
F3 - Open or shorted oven sensor - Replace oven sensor
Note am not 100% sure on the above.
First I would try unplugging or tripping the breaker for half an hour or so just to see if it will reset.
To check the oven sensor you will need a meter.
Following is a good site with general stove repair help. see #7 for the temp sensor
http://www.applianceaid.com/elecrange.html
Cannot advise on getting in a pro as I do not know how handy you are at this type of thing. One thing is for sure do not mess with it when it is plugged in.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Electric Range error Codes: F1 and F3 CKarras Oven Repair (including Ranges and Cooktops) 1 12-21-2009 04:19 AM
Fault Codes and Beeps hesper73 Oven Repair (including Ranges and Cooktops) 1 03-31-2009 06:41 AM
Dryer Fault Codes kayyjohnston Dryer Repair 1 01-08-2009 05:15 AM
CROSLEY electric range oven 50 degrees over setting-too hot liz Oven Repair (including Ranges and Cooktops) 2 07-03-2008 09:02 PM
Electric range Sears fault codes les roderfeld Oven Repair (including Ranges and Cooktops) 3 05-16-2008 08:43 PM
