Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   thermador MCM 255 - (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2625-thermador-mcm-255-a.html)
roxy 11-19-2007 09:25 AM
thermador MCM 255 -
I have a old Thermador MCM255 - combo microwave/convection and double oven below.
Recently, my microwave doesn't work, now my convection oven does not work.
I changed out the fuse in the back but still doesn't work. Any suggestions?
Is it worth repairing an 23 year wall oven?
Roxy:eek:
Gene 11-19-2007 08:11 PM
Unfortunately the convection heating and air distributing parts, as well as most microwave parts for your oven are no longer available.
marc shaw 01-06-2008 07:52 AM
Quote:
Gene, we are replacing the Thermador MCM 255 in my house. Do you have the overall dimensions. We are trying to buy a new unit and we need to know both the inside and outside dimensions. Thanks for any help you can provide. Marc Shaw.
Gene 01-08-2008 02:03 PM
Hi Marc,
I could not find the dimensions of such old oven.
You can measure the out side dimensions, then pull it out for a few inches and measure the cabinet opening.
I'm afraid some cabinet alterations should be necessary.
Best regards.
glenndott 05-03-2010 03:12 PM
Roxy I own the same model MCM255 you can replace just the micro wave unit for that model we did. not sure if Thermadore makes a compatable unit for this model now
zchannel 11-26-2010 08:37 AM
I was able to find a new microwave emitter and the microwave oven works great. My problem now is the plastic shelf guides are burning due to their age and I can keep them going for a little while longer by filing down the rough edges that catch the microwaves. That stops the smell. Also you have to keep the wire shelf away from the back so it doesn't arc. Some thermador service men are good at keeping this going. The shelf guides are discontinued by Bosch because it's a bad design to have a convection oven and a microwave in the same unit. You won't find those in modern replacements and I'm sure I'm not the first person to report these problems. I'm looking to replace the whole oven which measures 24-1/2 x 47-1/2 including the lower oven which is fine. But there are no microwave uppers and conventional lowers available in that width. Only 27" and 30" and that runs into cabinet repair. Would love to find the rack slide kit L & R. but all inventory among the obsolete parts people is gone. Good luck.
zchannel 11-26-2010 08:41 AM
Mcm-255 Micro/convect/conventional Wall Oven
