I received your sensor #8053344 which I assume is the same as AP3130719. The problem was the F-3 code and I was told this part should correct the problem. The problem now: the oven (it's a double wall oven) appears to have two sensors - one at the rear of the broiler - on top; another at the rear - under the drip pan. Which one should be replaced?
