Discuss
self clean locked up oven
 in
We replaced the Control Panel and finally got power to the oven but only by holding in the door latch.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » self clean locked up oven
  #21 (permalink)
Old 05-31-2018, 11:53 AM
Junior Member
Regier is on a distinguished road
Default Control Panel
We replaced the Control Panel and finally got power to the oven but only by holding in the door latch. So now we know it's worth ordering the latch next. What an engineering mess! There should be a recall on this! Thanks for all your help!
  #22 (permalink)
Old 05-31-2018, 12:34 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Regier, You're Very Welcome !!! Yes you will need the door S/C latch assembly. The control board/panel is designed to constantly check the door switch circuits, even in the TOD (time of day)mode. If or when a switch fails or a latch is in the wrong position this will present a door lock error code if the motor can't rotate the latch back to the proper position.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #23 (permalink)
Old 07-15-2018, 04:54 PM
Junior Member
powown is on a distinguished road
Default
Quote:
Originally Posted by Joe / APP Team View Post
Regier, Correct, the two blue wires (18-20 VAC) from the control transformer is the power supply for the display, signal and the communication to the relays. If you have the voltage across the two blue wires on the control board, but no display, the control is the issue.
Ok, we can understand the waiting on the door self clean latch assembly, power to the control and operation of the oven is more desirable.
Hi, I have the same problem with the oven after I turned on the self destruct, whoops, self-cleaning function. The oven door is now locked, which was opened by a coat hanger and there is 220V going into the oven and 24VAC going into the control board. What part is the control transformer that is needed so the oven works again?
  #24 (permalink)
Old 07-25-2018, 10:18 AM
Senior Expert
Default
Quote:
Powown, If you have 24 VDC at the control board, you shouldn't need the control transformer, and the control panel thermal fuse would be OK as well.
We're going to need the model number of your oven, so we can advise you properly, and if parts are needed, we will have the proper information so you can order the correct parts, and get you oven up and running. You may want to review the remainder of this thread, so you may have a better idea of other checks and possibilities. In the mean time, try and get us the model number of your oven. Thanks,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No power after self clean; door locked mulean Oven Repair (including Ranges and Cooktops) 14 11-01-2014 11:54 PM
No power door locked after self clean on Model# leatherneck Oven Repair (including Ranges and Cooktops) 1 04-04-2010 02:23 PM
REPOST: Whirlpool, Single door oven locked and not working after self clean kcboilerroom Oven Repair (including Ranges and Cooktops) 1 08-26-2009 10:47 AM
Whirlpool Oven Door locked/dead after self clean kcboilerroom Oven Repair (including Ranges and Cooktops) 0 08-12-2009 02:54 PM
Oven Clock , Locked door display blinking but not locked RaviM Oven Repair (including Ranges and Cooktops) 2 08-05-2009 05:47 PM
