Discuss
self clean locked up oven
 in
Hi Joe, Thanks for Info on the Fuse 1st person who could give me some answers... The Oven was in
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » self clean locked up oven
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 07-26-2011, 07:44 AM
Junior Member
ALopezCDP is on a distinguished road
Default Island Oven
Hi Joe,
The Oven was in Use at that time we had put it to do Self Cleaning in the PM Next AM it was Dead and Door Locked... It would not surprise me if During the PM hours we might have had a brown out it happens on Island a lot and or it had received other shut downs in the past 8 months and the self-cleaning did it in!!
TXS for your Help will let U know how it goes
  #12 (permalink)
Old 07-26-2011, 08:27 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by ALopezCDP View Post
Hi Joe,
Alopez,
Good Deal,
We'll keep an eye out for your response, I'm sure you'll be up and running soon.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #13 (permalink)
Old 11-08-2011, 02:46 PM
Junior Member
mvparent0 is on a distinguished road
Default
Hi Alopez and Joe,
If you check the Ikeafans website, this is a know problem with the Nutid oven. It tends to happen EVERY time a cleaning is run, unless you manually choose a short cleaning cycle. My suggestion would be to not run the cleaning cycle at all once your oven is fixed.
Joe -- Is there a way to test both the thermal overload device and the thermal fuse with a meter to see which one is bad? I have the oven disconnected, and I don't have a 220 line to test. The oven has been replaced, and I was going to send it to the dump. If it was a the thermal fuse that is the problem, I would be inclined to fix it and pass the oven on to someone to use (and keep it out of the landfill). Since the thermal overload is more expensive, I would probably just not go through the expense of fixing the oven.
Thanks!
Dan
  #14 (permalink)
Old 11-09-2011, 06:44 AM
Senior Expert
Default
Quote:
Originally Posted by mvparent0 View Post
Hi Alopez and Joe,
Thanks!
Dan
Dan,
You may want to try a revised thermal fuse,
Part number: AP4320019
This part is rated at a slightly higher temperature(we were told) and after you do all the checks listed in the previous posts( proper installation, door alignment, seals, etc.) , repalce the thermal fuse, you should be fine from there on out.
__________________
Joe M. APP TEAM
  #15 (permalink)
Old 05-02-2018, 03:34 PM
Junior Member
Regier is on a distinguished road
Default Replaced fuses and still no power
We bought the fuses and checked to make sure they worked... There's power to the unit but the unit does not have power. The lock didn't reset, the display doesn't light up, nothing. The gasket looks fine. There must've been something plastic on the lock/latch because it melted. Otherwise everything looks good. What do we replace next? Ours is an IKEA NUTID IBS550PWS00
  #16 (permalink)
Old 05-03-2018, 07:48 AM
Senior Expert
Default
Quote:
Regier, There are several things to check, start at the control transformer. Make sure you have 120 VAC across the black and white wires and 18 to 24 VAC across the two blue wires at the control board. Then re check the control panel thermal fuse, in the wiring harness between the transformer and the control board. It had to have gotten pretty warm to melt a part on the self clean door latch, but either way it will need to be replaced Part number: AP6016808
, And there is a "relocation" kit Part number: AP5803432
designed to help keep the controls and thermal fuses in the air flow and keep them from opening or being damaged(see the attachments).
__________________
Joe M. APP TEAM
  #17 (permalink)
Old 05-20-2018, 04:20 PM
Junior Member
Default Wires good but still no power
Joe, did what you recommend at the control transformer. I have 120 VAC across the black and white wires and 18 to 24 VAC across the two blue wires at the control board. Re checked the control panel thermal fuse, in the wiring harness between the transformer and the control board.
I haven't replaced the latch yet because there's no power to the display panel. Do you think replacing the latch will restore the power to the unit?
Also, I did order the reconfiguration kit, but if I'm not planning to use the self destruct button again, I'll probably return it.
  #18 (permalink)
Old 05-21-2018, 08:02 AM
Senior Expert
Default
Regier, If you have 120 VAC into the control transformer, and 18-20 VAC across the blue wires (JP03/3 & JP03/2) then you have power into the control
board. You can check for line voltage into the clock from the JP06/1 and JP06/2 to chassis ground but you're information says you have the needed voltage, and the problem is in the control.
With the way the control is wired and the circuits in the control constantly looking for the latch switch and door switch status, you'll need to replace the door latch assembly. If the control doesn't see the proper circuits, it will produce an error code and the oven will not work.
__________________
Joe M. APP TEAM
  #19 (permalink)
Old 05-21-2018, 08:40 AM
Junior Member
Default Power
For clarification:
If we have the needed voltage to the control, but the problem is in the control, we should replace the control transformer?
The clock does not have any light display whatsoever, so we will check those wires as well.
We'll order the latch assembly, but wanted to make sure that we could get power working first.
Thank you for your responses.
  #20 (permalink)
Old 05-21-2018, 09:49 AM
Senior Expert
Default
For clarification:
Regier, Correct, the two blue wires (18-20 VAC) from the control transformer is the power supply for the display, signal and the communication to the relays. If you have the voltage across the two blue wires on the control board, but no display, the control is the issue.
Ok, we can understand the waiting on the door self clean latch assembly, power to the control and operation of the oven is more desirable.
__________________
Joe M. APP TEAM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No power after self clean; door locked mulean Oven Repair (including Ranges and Cooktops) 14 11-01-2014 11:54 PM
No power door locked after self clean on Model# leatherneck Oven Repair (including Ranges and Cooktops) 1 04-04-2010 02:23 PM
REPOST: Whirlpool, Single door oven locked and not working after self clean kcboilerroom Oven Repair (including Ranges and Cooktops) 1 08-26-2009 10:47 AM
Whirlpool Oven Door locked/dead after self clean kcboilerroom Oven Repair (including Ranges and Cooktops) 0 08-12-2009 02:54 PM
Oven Clock , Locked door display blinking but not locked RaviM Oven Repair (including Ranges and Cooktops) 2 08-05-2009 05:47 PM
