The oven and broiler are not working. The stove burners are working fine. About a month ago the oven started to make aloud buzzing sound every time the heat up cycle would start. Now that buzzing sounds only happens when I try to first start the oven and the oven does not heat up. I don’t hear gas movement and I don’t smell any gas. There are no error codes on the display panel. The controls appear to work as expected. During the startup cycle there appears to be three distinct sounds. 1. A click from around the control panel (control replay?) 2. The new loud buzzing sound (gas control relay?) 3. three clicks (igniter?) I recorded the sound and posted it at: http://www.drrummel.com/Oven/OvenBuzz.mp3When I try to start the broiler, I don’t hear any sounds. The Gas Valve resistance reading are:Top (Broiler) 193 ohms Bottom (Oven) 195 ohmsMake: WhirlpoolModel: SF272LXTD 2
