| » After running self cleaning, tempature controls do not work properly |
Model Number: rbs305pdq6 Brand: Whirlpool Age: 5 - 10 years
Hello All,
I am renting a house that has an in wall Whirlpool rbs305pdq6 oven. I ran the self clean two nights ago and shut off the self clean a hour prior to the end of it's countdown per my landlords instructions. Now the next day, the oven turns on, but if I try to press the up arrow to make the temperature hotter, the temp goes down instead on the digital control. If I press the down arrow, it goes down to set the oven at a lower temp. So, I can no longer press the up arrow button to set the temperature higher than the default degrees when you press bake. Any ideas? Ads By Google Related Models |
Unfortunately, you have found a quirk in the control board (AP3009794) for these ovens that seems to show up after a self cleaning cycle is run. I have done at least 6 of these in the past and each one is exactly as you described. The problem is the boards are no longer available from most part houses so you may need to do some searching to get this one fixed.
I have the exact same issue with a RBS275PDB6 Whirlpool Oven. Is it the control panel #4451333 or the microcomputer #4452240? It may be a moot point because the control panel is virtually impossible to find. It is also about half the price of a new oven.
Thanks for your help. |
| Display Modes | |
| Controls will not work on the oven | Timmy Stanley | Oven Repair (including Ranges and Cooktops) | 4 | 07-16-2010 03:44 PM |
| Kitchin Aid Oven/micro fails to work after running self cleaning feature | Ranch of Hope | Oven Repair (including Ranges and Cooktops) | 1 | 12-07-2009 05:42 AM |
| Screen controls not functioning properly on Harmony Electric Dryer | MomWithBrokenHarmony | Dryer Repair | 1 | 10-24-2009 09:20 AM |
| KitchenAid Controls Don't Work | Tom John | Dishwasher Repair | 3 | 08-18-2009 04:40 PM |
| Oven controls won't work | docsgramps | Oven Repair (including Ranges and Cooktops) | 0 | 03-28-2009 11:55 AM |
