Discuss
Maytag Oven Light
 in
I'm having trouble getting the inside oven light cover off to replace the bulb. I guess the glass cover unscrews,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Oven Light
  #1 (permalink)
Old 03-09-2009, 09:26 AM
Junior Member
maytag bob is on a distinguished road
Lightbulb Maytag Oven Light
Model Number: CRE9400CCE   Brand: Maytag   Age: 1 - 5 years
I'm having trouble getting the inside oven light cover off to replace the bulb. I guess the glass cover unscrews, but it only turns a little, and won't come off. Any hints or suggestions?
Bob
Ads By Google
Related Models
Maytag CRE9400CCE RANGE- S/C F/S ELE
Maytag CRE9400CCL RANGE- S/C F/S ELE
Maytag CRE9400CCM RANGE- S/C F/S ELE
Maytag CRE9400CCW RANGE- S/C F/S ELE
Maytag CRE9500ACE RANGE- S/C F/S ELE
Maytag CRE9500ACL RANGE- S/C F/S ELE
Maytag CRE9500ACW RANGE- S/C F/S ELE
Maytag CRE9500ADE RANGE- S/C F/S ELE
Maytag CRE9500ADL RANGE- S/C F/S ELE
Maytag CRE9500ADW RANGE- S/C F/S ELE
Maytag CRE9500BCE RANGE- S/C F/S ELE
Maytag CRE9500BCL RANGE- S/C F/S ELE
Maytag CRE9500BCW RANGE- S/C F/S ELE
Maytag CRE9500BDE RANGE- S/C F/S ELE
Maytag CRE9500BDL RANGE- S/C F/S ELE
Maytag CRE9500BDW RANGE- S/C F/S ELE
Maytag CRE9500CCE RANGE- S/C F/S ELE
Maytag CRE9500CCM RANGE- S/C F/S ELE
Maytag CRE9500CDE RANGE- S/C F/S ELE
Maytag CRE9500CDL RANGE- S/C F/S ELE
Maytag CRE9500CDW RANGE- S/C F/S ELE
Maytag CRE9500DDE RANGE- S/C F/S ELE
Maytag CRE9500DDM RANGE- S/C F/S ELE
Maytag CRE9530BCB Range - S/c F/s Ele
Maytag CRE9530BCE RANGE- S/C F/S ELE
Maytag CRE9530BCM RANGE- S/C F/S ELE
Maytag CRE9530CDE RANGE- S/C F/S ELE
Maytag CRE9530CDM RANGE- S/C F/S ELE
Maytag CRE955 RANGE- S/C F/S ELE
Maytag CRE9590CCL RANGE- S/C F/S ELE
Maytag CRE9590CCW RANGE- S/C F/S ELE
Maytag CRE9600ACE RANGE- S/C F/S ELE
Maytag CRE9600ACL RANGE- S/C F/S ELE
Maytag CRE9600ACW RANGE- S/C F/S ELE
Maytag CRE9600ADE RANGE- S/C F/S ELE
Maytag CRE9600ADL RANGE- S/C F/S ELE
Maytag CRE9600ADW RANGE- S/C F/S ELE
Maytag CRE9600BCE RANGE- S/C F/S ELE
Maytag CRE9600BCL RANGE- S/C F/S ELE
Maytag CRE9600BCW RANGE- S/C F/S ELE
Maytag CRE9600CCE RANGE- S/C F/S ELE
Maytag CRE9600CCM RANGE- S/C F/S ELE
Maytag CRE9600CDE RANGE- S/C F/S ELE
Maytag CRE9600CDL RANGE- S/C F/S ELE
Maytag CRE9600CDW RANGE- S/C F/S ELE
Admiral CRE9600CGE RANGE- S/C F/S ELE
Maytag CRE9600DDE RANGE- S/C F/S ELE
Maytag CRE9600DDM RANGE- S/C F/S ELE
Maytag CRE9700ACB RANGE- S/C F/S ELE
Maytag CRE9700ACE RANGE- S/C F/S ELE
Maytag CRE9700ADB RANGE- S/C F/S ELE
Maytag CRE9700ADE RANGE- S/C F/S ELE
Maytag CRE9800ACB RANGE- S/C F/S ELE
Maytag CRE9800ACE RANGE- S/C F/S ELE
Maytag CRE9800ADB RANGE- S/C F/S ELE
Maytag CRE9800ADE RANGE- S/C F/S ELE
Maytag CRE9800BCB RANGE- S/C F/S ELE
Maytag CRE9800BCE RANGE- S/C F/S ELE
Maytag CRE9800CCB RANGE- S/C F/S ELE
Maytag CRE9800CCE RANGE- S/C F/S ELE
Maytag CRE9800CCM RANGE- S/C F/S ELE
Maytag CRE9800CDB RANGE- S/C F/S ELE
Maytag CRE9800CDE RANGE- S/C F/S ELE
Maytag CRE9800DDB RANGE- S/C F/S ELE
Maytag CRE9800DDE RANGE- S/C F/S ELE
Maytag CRE9800DDM RANGE- S/C F/S ELE
Maytag CRE9830BCB RANGE- S/C F/S ELE
Maytag CRE9830BCE RANGE- S/C F/S ELE
Maytag CRE9830BCM RANGE- S/C F/S ELE
Maytag CRE9830CDB RANGE- S/C F/S ELE
Maytag CRE9830CDE RANGE- S/C F/S ELE
Maytag CRE9830CDM RANGE- S/C F/S ELE
Maytag CRE9900ACB RANGE- S/C F/S ELE
Maytag CRE9900ACE RANGE- S/C F/S ELE
Admiral CREA200ACL RANGE- F/S STD ELE
Admiral CREA200ACW RANGE- F/S STD ELE
Admiral CREA300ACL RANGE- F/S STD ELE
Admiral CREA300ACW RANGE- F/S STD ELE
Admiral CREA400ACL RANGE- F/S STD ELE
Admiral CREA400ACW RANGE- F/S STD ELE
Admiral CREA450ACL RANGE- F/S STD ELE
Admiral CREA450ACW RANGE- F/S STD ELE
Admiral CREA600ACE RANGE- S/C F/S ELE
Admiral CREA600ACL RANGE- S/C F/S ELE
Admiral CREA600ACW RANGE- S/C F/S ELE
Admiral CREA650ACB RANGE- S/C F/S ELE
Admiral CREA650ACL RANGE- S/C F/S ELE
Admiral CREA650ACW RANGE- S/C F/S ELE
Admiral CREA750ACB RANGE- S/C F/S ELE
Admiral CREA750ACE RANGE- S/C F/S ELE
Admiral CREA750ACM RANGE- S/C F/S ELE
Frigidaire CREF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CREF342AS1 Dryer - Frig/best Buy
Frigidaire CREF342AS2 Frigidaire/electric Dryer
Crosley CREF366FBA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FCA BRADA CANADA/ELECTRIC RANGE
Crosley CREF366FSA BRADA CANADA/ELECTRIC RANGE
Frigidaire CRER442AS0 Dryer - Frig/best Buy
Frigidaire CRER442AS1 Dryer - Frig/best Buy
Frigidaire CRER442AS2 Dryer - Frig/best Buy
Frigidaire CRER5700AS0 Dryer - Frig/best Buy
Frigidaire CRER5700AS1 Frigidaire/electric Dryer
Frigidaire CRER7900AS0 Dryer - Frig/best Buy
Frigidaire CRER7900AS1 Frigidaire/electric Dryer
Amana CRF14 Misc / Accessory
Amana CRF14L Misc / Accessory
Amana CRFS14 Misc / Accessory
Amana CRFS14L Misc / Accessory
Maytag CRG0305AAL Range - F/s Std Gas
Maytag CRG0560AAW Range - F/s Std Gas
Maytag CRG0760AAL RANGE- S/C F/S GAS
Maytag CRG0760AAW RANGE- S/C F/S GAS
Maytag CRG0860AAL RANGE- S/C F/S GAS
Maytag CRG0860AAW RANGE- S/C F/S GAS
Maytag CRG200 RANGE- F/S STD GAS
Maytag CRG200B RANGE- F/S STD GAS
Maytag CRG300 RANGE- F/S STD GAS
Maytag CRG300B RANGE- F/S STD GAS
Maytag CRG305 RANGE- F/S STD GAS
Maytag CRG350 RANGE- F/S STD GAS
  #2 (permalink)
Old 03-09-2009, 10:57 AM
TechnicianBrian's Avatar
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Usually what happens is the lens sticks, then you start to spin the bulb holder assembly. If that is the case, usually your only option is to use some needle nosed pliers to hold onto the edge of the socket while you turn the lens. You may be able to get past the point it is stuck without damaging the holder, but if not, the holder may need to be replaced as well.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 03-09-2009, 03:48 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Try warming the oven up and then while warm remove the lens
Watch that you do not burn yourself
Odds are high that you will anyway, I usually do.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Oven 4: plus Red light Dave_Work_Number Oven Repair (including Ranges and Cooktops) 0 01-13-2010 05:01 AM
Maytag Gemini gas range upper oven won't light pontiac61 Oven Repair (including Ranges and Cooktops) 0 11-16-2009 09:10 AM
Maytag Oven ON Light stays on Madmax Oven Repair (including Ranges and Cooktops) 1 04-28-2009 07:27 PM
Maytag Oven Bake/Light Issue jimbonel Oven Repair (including Ranges and Cooktops) 1 11-26-2008 01:56 PM
Maytag Gas Range - oven will not light larksys Oven Repair (including Ranges and Cooktops) 0 05-22-2008 11:51 AM
