| » Half a burner not working |
Model Number: PGLEF385EC1 Brand: Frigidaire Age: 1 - 5 years
I have a Galery Seris ceramic top stove and the small inside burner of the right hand burner pair is not working. When I select the large burner, only the outer ring heats up, when I select the small option, nothing happens. How do I fix this?
Replacement parts for FRIGIDAIRE PGLEF385EC1 Frigidaire Canada/electric Range | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318046768.pdf And here is a manual which should help http://appliancedigest.com/index.php...ervice-manual/ You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. You will have to open it up and inspect the element. Often you can see where it has burned out. If it looks OK you will have to measure it with a meter to check if the heating coils are OK. If OK then odds are that the control needs replacing.
__________________
| Display Modes | |
| Half a burner | cjkim1030 | Oven Repair (including Ranges and Cooktops) | 1 | 04-24-2011 05:06 AM |
| Upper half not working | shyboy | Dishwasher Repair | 0 | 02-15-2011 08:41 AM |
| New rear tub half wont fit old front half | daaavey | Washer Repair | 0 | 10-23-2010 10:43 AM |
| GE Range, only half of burner works....... | FDAR | Oven Repair (including Ranges and Cooktops) | 0 | 11-01-2009 03:23 PM |
| Window A/c Working Half Efficiency | srbishoplx | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 08-06-2007 06:47 PM |
