Replaced control board because oven and broiler wouldn't work (Fault Code FFF). Now broiler works and oven heats up to set temperature; however, oven won't maintain set temperature. Once up to temperature, I hear the pre-heat alert, then oven flame goes off. As the oven cools, I hear clicks from the control board, and see the pilot come on, but, no burner flames.
