Discuss
Thermador oven dead
 in
Problem started as a dim display. This is the third time it went bad. Bought a display kit. Replaced board
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador oven dead
  #1 (permalink)
Old 11-16-2007, 08:50 PM
Cat Cat is offline
Junior Member
Cat is on a distinguished road
Default Thermador oven dead
Model Number: SCD302TP   Brand: Thermador   Age: 5 - 10 years
Problem started as a dim display. This is the third time it went bad. Bought a display kit. Replaced board and LCD panel.
Now oven does not work at all. We think maybe we broke the touchpad when uninstalling. A pin broke off when we were pulling the connector off (very hard to remove) but we had soddered back on. Is there a way to troubleshoot the touchpad to be sure this is the problem before I buy that part which is not cheap?
Also can the LCD display work with the old board? We replaced because it was recommended and we hoped it would resolve replacing the display every few years, but in case the problem is with the new board we would put the old one back in.
Thanksgiving a few days away.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 09:54 PM
shado118 shado118 is offline
Junior Member
shado118 is on a distinguished road
Default
I hate to say this and am not an expert but I had a similiar problem with my Thermador double oven. I Didn't squeeze the square power cable release and broke a pin, tried soldering sort of worked but to no avail. Then noticed a nick in the ribbon cable and pin problems with that. It even had non reactive touch buttons at times. I ended up getting an entire new unit express delivery, very expensive but have had no problems since.
  #3 (permalink)
Old 11-19-2007, 02:59 PM
Cat Cat is offline
Junior Member
Default
OK, I've accepted the fact I have to get the new touchpad part since that is how we broke ours. I also want to get a new wire harness for this. Anyone know where I can find the part #? When we put the square power cable on it, it went on either way. Aren't these suppose to go on just one way?
I notice on one part website they showed a fuse but the # did not correspond to anything on their blown out diagram. Anyone know where this fuse is located? I'd like to find out if this is blown too.
shado111, you mention a ribbon cable. If thin kind, not seperate white wires in a group, you should replace. We did while under warranty, was a manu defect. There was a notice in the parts box that these were a recall (not safety) because the heat caused the oven to go in error, which ours kept doing.
  #4 (permalink)
Old 11-19-2007, 03:37 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The part number for the keypad power harness AP2825647
What else do you need to help?
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Dbl Oven rcauthon Oven Repair (including Ranges and Cooktops) 1 01-07-2008 08:40 AM
Thermador wall oven bartt21999 Oven Repair (including Ranges and Cooktops) 0 10-30-2007 10:23 AM
Re-attaching Thermador Oven Door glegard Oven Repair (including Ranges and Cooktops) 1 10-13-2007 05:38 PM
Thermador oven door doesn't close deckerd Oven Repair (including Ranges and Cooktops) 1 10-03-2007 08:48 PM
GE oven dead after cleancycle Diet Oven Repair (including Ranges and Cooktops) 7 09-11-2007 02:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
