Gas is not released into the oven unless I tap or hit the valve & regulator assembly (Part #9752698), which I replaced 1 week ago. The oven will heat when the valve & regulator is tapped. After the temperature is reached the gas is turned off. The oven will not maintain the temperature unless I tap on the valve & regulator again. I cannot locate any loose electrical connections.
Has anyone experienced this issue?
