Bottom element did not heat at all. Can you help me what can be the reason? Will be the switch or the element ?? Only the top element works fine. Please let me know what part do i need to buy to fix that problem. Thank You
If the bake element ( AP3743953) isn't heating, very likely it has failed and needs to be replaced. If you have a multimeter handy, it is best to do a resistance check of the element just to be sure. The control board can also be the problem and a multimeter voltage check to the bake element wires would confirm it's operation.
Thank you Brian, You were right, it was just what you said !!! It was only the element. I did not expend more money buying something else and the installation was very easy.:) This Web page is really helpfull to fix and order the right parts, thank you again.
