I just boiled over some pasta water all over my cooktop and the burners automatically turned off. They are now beeping and showing an error code E on one burner and a number 11 on the other burner. The oven works but I cant get the error codes to turn off, none of the burners turn on, and the beeping is constant. What do I do?:confused:
A model number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman A model number may help others help you. Thanks, but I turned the breaker off for an hour and cleaned the cooktop to make sure there were no "false reading" for something on the stove and it cleared itself up.:)
