I was replacing a broken door handle on my daughter's stove when the front glass and 2 side trims came off. In trying to replace them, the plastic hinges broke. I was having trouble fitting the glass back into the trim edges. I left the door on when trying this. I'm sure there is an easier way and would be grateful if you would share it with me. Thanks.
