| » Oven will not heat |
Model Number: ww30430w Brand: Jenn-Air Age: More than 10 years
A year ago I had my top oven repaired because it would not heat up. It was this same time of year so the repairman solder something together instead of ordering a part to get us by. Well it has happened again and I cannot remember the name of the part that I need. The oven will broil and if I turn it to broil first and then turn it off, then turn on to bake I can sometimes get the oven to heat up. It seems to have a short. Any suggestions?
Related Models |
Most likely the problem with your oven is a bad relay board.
- The part number for the new relay board AP378359 - Here are the break down diagrams for the Jenn Air oven Model WW30430W Gene.
__________________
Professional appliance repair in Orange County, California. |
| Display Modes | |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Oven/clock Control Panel is no longer lit but oven does heat. | jthomas@abrakadoodle.com | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2009 04:07 PM |
| Oven broiler and burners work - oven will not heat | fatbuford | Oven Repair (including Ranges and Cooktops) | 0 | 11-27-2009 05:50 AM |
| Caloric double oven/bottom oven doesn't heat | kj0505 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2008 09:14 AM |
| Bosch 27" Dbl oven Powering on but no heat either oven | badace | Oven Repair (including Ranges and Cooktops) | 0 | 12-02-2007 09:56 AM |
