Discuss
ignitor question
 in
The broiler and oven are not working I replaced the thermostat switch same problem. clock, burners, and oven light working.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ignitor question
  #1 (permalink)
Old 11-15-2007, 06:14 PM
Rod Weeks Rod Weeks is offline
Junior Member
Rod Weeks is on a distinguished road
Default ignitor question
Model Number: RGB528BEA1AD   Brand: Hotpoint   Age: 5 - 10 years
The broiler and oven are not working I replaced the thermostat switch same problem. clock, burners, and oven light working. I was told it could be the ignitor and since I can not return the thermostat I do not want to waste any more money. Any ideas Thank you
Related Models
General Electric RGB528BEA1AD Gas range
General Electric RGB528BEA1CT Gas range
General Electric RGB528BEA1WH Gas range
General Electric RGB528BEA2AD Gas range
General Electric RGB528BEA2CT Gas range
General Electric RGB528BEA2WH Gas range
General Electric RGB528BEA3AD Gas range
General Electric RGB528BEA3CT Gas range
General Electric RGB528BEA3WH Gas range
General Electric RGB528BEA4CT Gas range
General Electric RGB528BEA4WH Gas range
General Electric RGB528BEA5WH Gas range
General Electric RGB528BEA6WH Gas range
General Electric RGB528EH1 Gas range
General Electric RGB528EJ1 Gas range
General Electric RGB528EJ2 Gas range
General Electric RGB528EJ3 Gas range
General Electric RGB528EN1 Gas range
General Electric RGB528ER1 Gas range
General Electric RGB528ER2 Gas range
General Electric RGB528ER3 Gas range
General Electric RGB528ER4 Gas range
General Electric RGB528ET1WW Gas range
General Electric RGB528ET2WW Gas range
General Electric RGB528ET3WW Gas range
General Electric RGB528ET4WW Gas range
General Electric RGB528F0 Gas range
General Electric RGB528F1 Gas range
General Electric RGB528G1F0 Gas range
General Electric RGB528G1F1 Gas range
General Electric RGB528GEH1 Electric range
General Electric RGB528GEJ1 Gas range
General Electric RGB528GEJ2 Gas range
General Electric RGB528GEJ3 Gas range
General Electric RGB528GEN1 Gas range
General Electric RGB528GER1 Gas range
General Electric RGB528GER2 Gas range
General Electric RGB528GER3 Gas range
General Electric RGB528GER4 Gas range
General Electric RGB528GER5 Gas range
General Electric RGB528GET1AD Gas range
General Electric RGB528GET1WH Gas range
General Electric RGB528GET2AD Gas range
General Electric RGB528GET2WH Gas range
General Electric RGB528GEV1AD Gas range
General Electric RGB528GEV1WH Gas range
General Electric RGB528GEV2AD Gas range
General Electric RGB528GEV2WH Gas range
General Electric RGB528GEV3AD Gas range
General Electric RGB528GEV3WH Gas range
General Electric RGB528GF0 Gas range
General Electric RGB528GF1 Gas range
General Electric RGB528GPH1 Gas range
General Electric RGB528GPJ1 Gas range
General Electric RGB528GPJ2 Gas range
General Electric RGB528GPJ3 Gas range
General Electric RGB528PEA1WW Gas range
General Electric RGB528PEA2WW Gas range
General Electric RGB528PEA5WW Gas range
General Electric RGB528PEH1WW Gas range
General Electric RGB528PEH2WW Gas range
General Electric RGB528PH1 Gas range
General Electric RGB528PJ1 Gas range
General Electric RGB528PJ2 Gas range
General Electric RGB528PJ3 Gas range
General Electric RGB529GEP1 Gas range
General Electric RGB529GEP2 Gas range
General Electric RGB529GEP3 Gas range
General Electric RGB529GEP4 Gas range
General Electric RGB530BEA1AD Gas range
General Electric RGB530BEA1WH Gas range
General Electric RGB530BEA2AD Gas range
General Electric RGB530BEA2WH Gas range
General Electric RGB530BEA3AD Gas range
General Electric RGB530BEA3WH Gas range
General Electric RGB530BEW1AD Gas range
General Electric RGB530BEW1WH Gas range
General Electric RGB530BEW2AD Gas range
General Electric RGB530BEW2WH Gas range
General Electric RGB530BEW3AD Gas range
General Electric RGB530BEW3WH Gas range
General Electric RGB532BEA1AD Gas range
General Electric RGB532BEA1CT Gas range
General Electric RGB532BEA1WH Gas range
General Electric RGB532BEA2AD Gas range
General Electric RGB532BEA2CT Gas range
General Electric RGB532BEA2WH Gas range
General Electric RGB532BEA3CT Gas range
General Electric RGB532BEA4AD Gas range
General Electric RGB532BEA4CT Gas range
General Electric RGB532BEA4WH Gas range
General Electric RGB532BEA5AD Gas range
General Electric RGB532BEA5WH Gas range
General Electric RGB532BEA6WH Gas range
General Electric RGB532BEA7WH Gas range
General Electric RGB532BEA8WH Gas range
General Electric RGB532BEW1AD Gas range
General Electric RGB532BEW1WH Gas range
General Electric RGB532BEW2AD Gas range
General Electric RGB532BEW2WH Gas range
General Electric RGB532BEW3AD Gas range
General Electric RGB532BEW3WH Gas range
General Electric RGB532ET1AD Gas range
General Electric RGB532ET1WH Gas range
General Electric RGB532ET2AD Gas range
General Electric RGB532ET2WH Gas range
General Electric RGB532EV1AD Gas range
General Electric RGB532EV1WH Gas range
General Electric RGB532EV2AD Gas range
General Electric RGB532EV2WH Gas range
General Electric RGB533BEK1BB Gas range
General Electric RGB533BEK2BB Gas range
General Electric RGB533CEH1CC Gas range
General Electric RGB533CEH2CC Gas range
General Electric RGB533CEH3CC Gas range
General Electric RGB533CEH4CC Gas range
General Electric RGB533CEH5CC Gas range
General Electric RGB533ET1WW Gas range
General Electric RGB533ET2WW Gas range
General Electric RGB533EV2WW Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ignitor jstival1 Oven Repair (including Ranges and Cooktops) 1 07-13-2009 02:13 PM
ignitor Bobkc Dryer Repair 0 03-14-2009 12:05 PM
Ignitor test question davedorsett Oven Repair (including Ranges and Cooktops) 3 01-12-2009 10:24 AM
Gas ignitor Loretta Oven Repair (including Ranges and Cooktops) 3 03-30-2008 05:39 PM
how to get to the ignitor christena Dryer Repair 1 11-12-2007 07:45 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
