My Kitchen Aid broiler is not working properly. It heats up to a point where it warms the food but that's the extent of its use. I found the parts list on APP but no clue which part I should order to fix. Any advise is greatly appreciated.
Thanks in advance.
Chet
If the broiler looks like it ignites the first few times, then after that the igniter glows but the gas won't ignite, then the igniter () may need replacing. After several years the igniter's will no longer be able to turn on the gas valve more than a few times in a row before it needs to cool down. They are easy enough to replace if this is what the problem seems to be.
