Discuss
Non heating Top Oven Electric Jenn-Air
 in
Have 20 year old Jenn-Air double oven - bottom heats / works fine. Top entirely cold - both elements non
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Non heating Top Oven Electric Jenn-Air
  #1 (permalink)
Old 06-20-2011, 08:33 PM
Junior Member
gogto is on a distinguished road
Default Non heating Top Oven Electric Jenn-Air
Model Number: W256W   Brand: Jenn-Air   Age: More than 10 years
Have 20 year old Jenn-Air double oven - bottom heats / works fine. Top entirely cold - both elements non functional but were working fine a day before. Convection fan turns on / control panel has no error codes and functions normally.
I measured the voltage and resistance of the bottom element of the top oven. With the oven off but the element still connected to the oven, the resistance is around 22 ohms. When I turn the oven on and measure voltage, the meter is a solid 0 before the normal oven clicks (relay?) then gives noise of +- .1 on a 200V scale. I believe the elements are ok, and the front control panel is fine too (purchased and installed this first before looking into the problem in detail thinking that was the fix) so this leads me to the right relay board on the back after looking at the schematics. I believe the left relay is the bottom oven (which is working fine) and the right relay board is for the top? Otherwise, is there any other possible reason why the top oven (both elements) are not getting voltage? Believe it is the right pcb located on the fan assembly (the Y04100260) relay board. I have examined the existing part marked (JA204710 / 100-328-01) and the listed part (Y04100260) and am requesting help with two things. 1. To review if my logic is correct and 2. If it is, can I get some guidance on the correct way to determine if the board is bad?
Thanks.
Related Models
Jenn-Air W256W WALLOVEN- S/C ELE
Jenn-Air W256W-C WALLOVEN- S/C ELE
Admiral W25D6A WASHER-TOP LOADING
Admiral W25D6HW WASHER-TOP LOADING
Admiral W25D6W WASHER-TOP LOADING
Magic Chef W25EA2 WASHER-TOP LOADING
Magic Chef W25EN2 WASHER-TOP LOADING
Magic Chef W25EY2 WASHER-TOP LOADING
Magic Chef W25FA2 WASHER-TOP LOADING
Magic Chef W25FN2 WASHER-TOP LOADING
Magic Chef W25FY2 WASHER-TOP LOADING
Magic Chef W25HA2 WASHER-TOP LOADING
Magic Chef W25HN2 WASHER-TOP LOADING
Magic Chef W25HY2 WASHER-TOP LOADING
Jenn-Air W266 WALLOVEN- S/C MWAVE ELE
Magic Chef W26D6A WASHER-TOP LOADING
Magic Chef W26D6HW WASHER-TOP LOADING
Magic Chef W26D6W WASHER-TOP LOADING
Magic Chef W26EA2 WASHER-TOP LOADING
Magic Chef W26EN2 WASHER-TOP LOADING
Magic Chef W26EY2 WASHER-TOP LOADING
Magic Chef W26FA2 WASHER-TOP LOADING
Magic Chef W26FA2K WASHER-TOP LOADING
Magic Chef W26FN2 WASHER-TOP LOADING
Magic Chef W26FN2K WASHER-TOP LOADING
Magic Chef W26FY2 WASHER-TOP LOADING
Magic Chef W26FY2K WASHER-TOP LOADING
Magic Chef W26HA2 WASHER-TOP LOADING
Magic Chef W26HA2K WASHER-TOP LOADING
Magic Chef W26HA5K WASHER-TOP LOADING
Magic Chef W26HN2 WASHER-TOP LOADING
Magic Chef W26HN2K WASHER-TOP LOADING
Magic Chef W26HN5K WASHER-TOP LOADING
Magic Chef W26HY2 WASHER-TOP LOADING
Magic Chef W26HY2K WASHER-TOP LOADING
Magic Chef W26HY5K WASHER-TOP LOADING
Jenn-Air W27100B WALLOVEN- S/C ELE
Jenn-Air W27100BC WALLOVEN- S/C ELE
Jenn-Air W27100W WALLOVEN- S/C ELE
Jenn-Air W27100WC WALLOVEN- S/C ELE
Jenn-Air W27200B WALLOVEN- S/C ELE
Jenn-Air W27200BC WALLOVEN- S/C ELE
Jenn-Air W27200W WALLOVEN- S/C ELE
Jenn-Air W27200WC WALLOVEN- S/C ELE
Jenn-Air W2720B WALLOVEN- S/C ELE
Jenn-Air W2720B-C WALLOVEN- S/C ELE
Jenn-Air W2720W WALLOVEN- S/C ELE
Jenn-Air W2720W-C WALLOVEN- S/C ELE
Jenn-Air W27400B WALLOVEN- S/C ELE
Jenn-Air W27400W WALLOVEN- S/C ELE
Jenn-Air W2750B WALLOVEN- S/C ELE
Jenn-Air W2750B-C WALLOVEN- S/C ELE
Jenn-Air W2750W WALLOVEN- S/C ELE
Jenn-Air W2750W-C WALLOVEN- S/C ELE
Jenn-Air W276 WALLOVEN- S/C MWAVE ELE
Jenn-Air W276W WALLOVEN- S/C MWAVE ELE
Jenn-Air W2780B WALLOVEN- S/C ELE
Jenn-Air W2780B-C WALLOVEN- S/C ELE
Jenn-Air W2780W WALLOVEN- S/C ELE
Jenn-Air W2780W-C WALLOVEN- S/C ELE
Whirlpool W2RXEMMWB00 REFRIGERATOR
Whirlpool W2RXEMMWB01 REFRIGERATOR
Whirlpool W2RXEMMWQ00 REFRIGERATOR
Whirlpool W2RXEMMWQ01 REFRIGERATOR
Whirlpool W2RXEMMWS00 REFRIGERATOR
Whirlpool W2RXEMMWS01 REFRIGERATOR
Whirlpool W2RXNMMWB00 REFRIGERATOR
Whirlpool W2RXNMMWB01 REFRIGERATOR
Whirlpool W2RXNMMWB02 REFRIGERATOR
Whirlpool W2RXNMMWL00 REFRIGERATOR
Whirlpool W2RXNMMWL01 REFRIGERATOR
Whirlpool W2RXNMMWL02 REFRIGERATOR
Whirlpool W2RXNMMWQ00 REFRIGERATOR
Whirlpool W2RXNMMWQ01 REFRIGERATOR
Whirlpool W2RXNMMWQ02 REFRIGERATOR
Jenn-Air W30100B WALLOVEN- S/C ELE
Jenn-Air W30100BC WALLOVEN- S/C ELE
Jenn-Air W30100W WALLOVEN- S/C ELE
Jenn-Air W30100WC WALLOVEN- S/C ELE
Jenn-Air W30400B WALLOVEN- S/C ELE
Jenn-Air W30400BC WALLOVEN- S/C ELE
Jenn-Air W30400P WALLOVEN- S/C ELE
Jenn-Air W30400PC WALLOVEN- S/C ELE
Jenn-Air W30400PF WALLOVEN- S/C ELE
Jenn-Air W30400PG WALLOVEN- S/C ELE
Jenn-Air W30400PK WALLOVEN- S/C ELE
Jenn-Air W30400PR WALLOVEN- S/C ELE
Jenn-Air W30400PU WALLOVEN- S/C ELE
Jenn-Air W30400PV ELECTRIC WALL OVEN
Jenn-Air W30400W WALLOVEN- S/C ELE
Jenn-Air W30400WC WALLOVEN- S/C ELE
Whirlpool W3CG3014XB00 30" GAS COOKTOP
Whirlpool W3CG3014XS00 30" GAS COOKTOP
Whirlpool W3CG3014XW00 30" GAS COOKTOP
Whirlpool W4TXNGFWQ00 REFRIGERATOR
Whirlpool W4TXNGFWQ01 REFRIGERATOR
Whirlpool W4TXNGFWQ02 REFRIGERATOR
Whirlpool W4TXNWFWB01 REFRIGERATOR
Whirlpool W4TXNWFWQ00 REFRIGERATOR
Whirlpool W4TXNWFWQ01 REFRIGERATOR
Whirlpool W4TXNWFWQ02 REFRIGERATOR
Whirlpool W4TXNWFWT00 REFRIGERATOR
Whirlpool W4TXNWFWT01 REFRIGERATOR
Whirlpool W4TXNWFWT02 REFRIGERATOR
Whirlpool W5CE3024XB00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CE3024XS00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CE3024XW00 30" ELECTRIC BUILT-IN COOKTOP
Whirlpool W5CG3024XB00 30" GAS COOKTOP
Whirlpool W5CG3024XS00 30" GAS COOKTOP
Whirlpool W5CG3024XT00 30" GAS COOKTOP
Whirlpool W5CG3024XW00 30" GAS COOKTOP
Whirlpool W5CG3625XB00 30" GAS COOKTOP
Whirlpool W5CG3625XS00 30" GAS COOKTOP
Whirlpool W5CG3625XW00 30" GAS COOKTOP
Whirlpool W5TXDWFXQ00 REFRIGERATOR
Whirlpool W5TXEWFWB00 REFRIGERATOR
Whirlpool W5TXEWFWQ00 REFRIGERATOR
Whirlpool W5TXEWFWT00 REFRIGERATOR
Whirlpool W5TYDWFXQ00 REFRIGERATOR
Whirlpool W5WCE055XW0 AIR CONDITIONER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
need to get rid of Jenn Air electric oven with downdraft becky1107 Oven Repair (including Ranges and Cooktops) 0 11-24-2010 08:34 AM
jenn air electric oven F5 error smokey12 Oven Repair (including Ranges and Cooktops) 0 11-11-2010 04:27 PM
Jenn-Air built-in electric oven artmck Oven Repair (including Ranges and Cooktops) 0 11-09-2009 05:35 PM
Oven lock switch on Jenn-Air electric oven miriamgreen Oven Repair (including Ranges and Cooktops) 0 10-21-2009 01:40 PM
Jenn Air Electric Oven Not Heating CHXSailor Oven Repair (including Ranges and Cooktops) 6 01-04-2008 03:18 PM
