Discuss
Thermador Pro Range Griddle not igniting
 in
The griddle worked fine for a few years, then about 2 years ago it started to give out, that's when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Pro Range Griddle not igniting
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-04-2009, 08:20 PM
Junior Member
a91030Mom is on a distinguished road
Default Thermador Pro Range Griddle not igniting
Model Number: PGR486GDZS   Brand: -brand-   Age: 1 - 5 years
The griddle worked fine for a few years, then about 2 years ago it started to give out, that's when I began having trouble getting it to ignite. When I turned the griddle on I could hear a click and the igniter click, but just for a split second. I didn't smell any gas. I would have to turn the griddle on and off several times and maybe after a dozen tries or so, it would finally ignite. I got tiered of the whole thing and just started taking the "plate" off and setting on the two burners to the right of the griddle, when I had to use it. Well, we have a tradition of making pancakes every Sunday, so this is now getting old!
Last Friday I took the thing apart, the U-shaped tube where the flame comes out looks very good, nothing blocking any of the holes or anything like that. The flame igniter also looks very clean and "normal" (to me). I took more of it apart. I got under the sheet metal thing and saw where the solenoid valve was (I’ve been told it’s the solenoid valve). I unplugged the two electrodes (one blue one pinkish). I then unscrewed it from the gas supply. (See picture A) Lots of gas immediately came gushing out, so I quickly screwed it back on. I then re-plugged the two electrodes back where they were. I didn't know what else I could do, so I just put it back together and guess what, it turned on first try and worked like a champ!
I tested it often the rest of the day, turning the griddle on the gas would hear the gas come on and the igniter would turn on (nice strong blue line between the two points for as long as it took to get the flame going). Again, it turned on perfectly first try. I tested the next day, and NO GO. Back to square one.
I took the thing apart again today and unplugged the same stuff as last time, plugged the blue and pink back in, turned the griddle knob and nothing. I didn’t re-assemble all but, when I turn the griddle knob, the gas does not come out of the valve and the igniter doesn’t light, so basically it didn’t “magically” heal itself like last Friday.
Any ideas on how to proceed, what to test, etc. Let me know. I’m a housewife, but pretty handy. If I have to start replacing stuff, I want to start with the cheapest part first, then move on from there. (I once fixed my dryer by replacing a $10 part, only AFTER replacing a $100 part that didn’t do the trick; learned my lesson).
PS: I took my pictures to a local appliance repair shop to see how much this part (solenoid) cost. They first told me it’s called a solenoid and second said the manufacturer doesn’t make it anymore and has no suggestions for a replacement. I find this hard to believe, anyone know if this is true?
Picture A, depicts the solenoid valve and the two electrodes.
Picture B, depicts the view of the inside of the range, right behind the griddle knob.
Picture C, depicts where the blue and pink electrode wires go to, some computer thing on the side of the range under a burner.
Related Models
Maytag PGR5702BDH RANGE- F/S STD GAS
Maytag PGR5702BDT RANGE- F/S STD GAS
Maytag PGR5705BDH RANGE- S/C F/S GAS
Maytag PGR5705BDT RANGE- S/C F/S GAS
Maytag PGR5710BDC RANGE- S/C F/S GAS
Maytag PGR5710BDQ RANGE- S/C F/S GAS
Maytag PGR5710BDW RANGE- S/C F/S GAS
Maytag PGR5715BDQ RANGE- S/C F/S GAS
Maytag PGR5715BDW RANGE- S/C F/S GAS
Maytag PGR5720LDQ RANGE- S/C F/S GAS
Maytag PGR5720LDW RANGE- S/C F/S GAS
Maytag PGR5750LDQ RANGE- S/C F/S GAS
Maytag PGR5750LDS RANGE- S/C F/S GAS
Maytag PGR5750LDW RANGE- S/C F/S GAS
Maytag PGS3759BDB RANGE- S/C S/I GAS
Maytag PGS3759BDS RANGE- S/C S/I GAS
Maytag PGS3759BDW RANGE- S/C S/I GAS
General Electric PGS908BEM1BB Gas range
General Electric PGS908BEM2BB GAS RANGE
General Electric PGS908BEM3BB GAS RANGE
General Electric PGS908CEM1CC Gas range
General Electric PGS908CEM2CC GAS RANGE
General Electric PGS908CEM3CC GAS RANGE
General Electric PGS908DEP1BB GAS RANGE
General Electric PGS908DEP1CC GAS RANGE
General Electric PGS908DEP1WW GAS RANGE
General Electric PGS908DEP2BB GAS RANGE
General Electric PGS908DEP2WW GAS RANGE
General Electric PGS908SEM1SS Gas range
General Electric PGS908SEM2SS GAS RANGE
General Electric PGS908SEM3SS GAS RANGE
General Electric PGS908SEP1SS GAS RANGE
General Electric PGS908SEP2SS GAS RANGE
General Electric PGS908WEM1WW Gas range
General Electric PGS908WEM2WW GAS RANGE
General Electric PGS908WEM3WW GAS RANGE
General Electric PGS968BEM1BB GAS RANGE
General Electric PGS968BEM2BB GAS RANGE
General Electric PGS968BEM3BB GAS RANGE
General Electric PGS968DEP1BB GAS RANGE
General Electric PGS968DEP2BB GAS RANGE
General Electric PGS968KEM1CC GAS RANGE
General Electric PGS968KEM2CC GAS RANGE
General Electric PGS968SEM1SS GAS RANGE
General Electric PGS968SEM2SS GAS RANGE
General Electric PGS968SEM3SS GAS RANGE
General Electric PGS968SEP1SS GAS RANGE
General Electric PGS968SEP2SS GAS RANGE
General Electric PGS968TEM1WW GAS RANGE
General Electric PGS968TEM2WW GAS RANGE
General Electric PGS968TEM3WW GAS RANGE
General Electric PGS968TEP1WW GAS RANGE
General Electric PGS968TEP2WW GAS RANGE
General Electric PGS975BEM1BB Gas range
General Electric PGS975BEM2BB GAS RANGE
General Electric PGS975BEM3BB GAS RANGE
General Electric PGS975BEM4BB GAS RANGE
General Electric PGS975DEP1BB GAS RANGE
General Electric PGS975DEP1WW GAS RANGE
General Electric PGS975DEP2BB GAS RANGE
General Electric PGS975DEP2WW GAS RANGE
General Electric PGS975SEM1SS Gas range
General Electric PGS975SEM2SS GAS RANGE
General Electric PGS975SEM3SS GAS RANGE
General Electric PGS975SEM4SS GAS RANGE
General Electric PGS975SEP1SS GAS RANGE
General Electric PGS975SEP2SS GAS RANGE
General Electric PGS975WEM1WW Gas range
General Electric PGS975WEM2WW GAS RANGE
General Electric PGS975WEM3WW GAS RANGE
General Electric PGS975WEM4WW GAS RANGE
General Electric PGSS5NFXASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFYASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFZASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFZBSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5NFZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJXASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJXBSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJXCSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJYASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJZASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5PJZCSS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5RKZASS BOTTOM MOUNT REFRIGERATOR
General Electric PGSS5RKZCSS BOTTOM MOUNT REFRIGERATOR
Amana PGT-151UWW RANGE- S/C S/I DDRAFT GAS
Amana PGT-183UWW RANGE- S/C S/I DDRAFT GAS
Amana PGT120UB SURFACE UNIT- GAS
Amana PGT120UW SURFACE UNIT- GAS
Amana PGT130 SURFACE UNIT- GAS
Amana PGT130-UD RANGE- S/C S/I DDRAFT GAS
Amana PGT130-UWW RANGE- S/C S/I DDRAFT GAS
Amana PGT130UB1 SURFACE UNIT- GAS
Amana PGT130UD SURFACE UNIT- GAS
Amana PGT130UWW SURFACE UNIT- GAS
Amana PGT130UWW1 SURFACE UNIT- GAS
Amana PGT136 SURFACE UNIT- GAS
Amana PGT136-UD RANGE- S/C S/I DDRAFT GAS
Amana PGT136-UWW RANGE- S/C S/I DDRAFT GAS
Amana PGT136UB1 SURFACE UNIT- GAS
Amana PGT136UD SURFACE UNIT- GAS
  #2 (permalink)
Old 05-16-2009, 01:07 PM
Junior Member
nonlocal is on a distinguished road
Default Same problem
I have the same problem with my griddle igniter. About 50% of the time, when lighting, it will have a shorter than normal spark and will not light. I have to turn the knob to off and then back on to a temp again to try to re-light. My igniter has two prongs which I assumed the spark would pass between. However, I am seeing the spark travel to the burner instead whether or not it lights or is a short duration and doesn't light. Have you observed the spark when you have a failure to light? It would be interesting to know if your spark jumps to the burner like mine when it fails.
I was hoping to fix mine by getting the spark to jump between the prongs.
I am going to poke around some more and see if I can get a schematic of the igniter circuit.
Scott
  #3 (permalink)
Old 05-18-2009, 09:41 PM
Junior Member
Default I got mine working, here is how
Thermador Pro-Range PGR486GDZS 48 Griddle not igniting - Appliance Blog Repair Forums
The whole thing is at the above URL (different forum/blog). There are two pages.
Best of luck!
  #4 (permalink)
Old 05-19-2009, 05:12 AM
Junior Member
Default Found you on that forum too
Right after I posted on this blog I found your long exchange with Brian on the other blog. Looked like exactly the same symptoms so I ripped out the igniter circuit block and it was identical to that part you were replacing. I ordered one and have my fingers crossed!
  #5 (permalink)
Old 03-08-2015, 01:39 PM
Junior Member
GeoEdwards is on a distinguished road
Default Simmer burner goes out
I have the same issue on my Thermador PRG364GDUS. I am glad an electrical engineer is tackling it. It seems to me, if I have ignition and I do, and I have gas and I do, and it burns for a bit then arbitrarily turns off, it is probably in the circuitry controlling the valve.
It appears the on/off nature of the simmer burners are regulated by the potentiometer assembly which includes circuit boards that go in front of the two simmer valves that connect to a blue box that is directly behind the kick plate at the bottom of the range.
BOSCH POTENTIOMETER KIT 497235
If you figure it out, let me know. I love my stove and cook an awful lot.
George
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador griddle problem euroah Oven Repair (including Ranges and Cooktops) 0 10-14-2009 01:19 PM
Jenn Air Range not Igniting jwag Oven Repair (including Ranges and Cooktops) 0 07-25-2009 05:23 PM
thermador griddle element james99aa Oven Repair (including Ranges and Cooktops) 0 06-18-2009 03:15 PM
Thermador griddle thermostat replacement David Jones Oven Repair (including Ranges and Cooktops) 0 04-07-2009 09:37 AM
Thermador Griddle Igniting Issues dsprings Oven Repair (including Ranges and Cooktops) 0 05-31-2008 02:17 PM
