I just replace Oven bake element # Wb44x200 for this model. GE mongram JKP40GK1WG After replacing part, I then proceed to put oven on clean mode. after clean mode was over but lights were not out because it has to cool down, I had to leave my home so I turned off circut breaker so the oven was no longer on. when I came back and turn the breaker back on the oven seems to be still on both lights are on. I then turned the knobs left and right it doesnot seem to turn off any test to check you call if you like 631-277-6273 ken
