Discuss
Replacement of oven glass, inside door
 in
I need to purchase a glass replacement for the inside door of my KitchenAid Superba gas oven. Also, I would
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replacement of oven glass, inside door
  #1 (permalink)
Old 06-17-2011, 01:22 PM
Junior Member
trancedestroyer is on a distinguished road
Default Replacement of oven glass, inside door
Model Number: KGST307HBS4   Brand: Kitchen Aid   Age: 1 - 5 years
I need to purchase a glass replacement for the inside door of my KitchenAid Superba gas oven. Also, I would like to do the installation and need a manual or photographs with directions. Please advise! Thank you!
Related Models
Whirlpool KGST307HBS4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBS6 RANGE
Whirlpool KGST307HBS8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBS9 GAS SLIDE IN RANGE
Whirlpool KGST307HBT0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT2 GAS SLIDE IN RANGE
Whirlpool KGST307HBT3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBT6 RANGE
Whirlpool KGST307HBT8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBT9 GAS SLIDE IN RANGE
Whirlpool KGST307HWH0 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH2 GAS SLIDE IN RANGE
Whirlpool KGST307HWH3 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH4 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HWH6 RANGE
Whirlpool KGST307HWH8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HWH9 GAS SLIDE IN RANGE
Amana KGT-591 RANGE- S/C S/I DDRAFT GAS
Amana KGT-593 RANGE- S/C S/I DDRAFT GAS
Amana KGT-693 RANGE- S/C S/I DDRAFT GAS
Amana KGT341 SURFACE UNIT- GAS
KitchenAid KGTC366EAL0 36" GAS GLASS BURNER COOKTOP
Admiral KGU5700BS REF - SXS
Admiral KGU57990KD REF - SXS/I&W
Admiral KGU5950BS REF - SXS
Admiral KGU5955BS REF - SXS
Admiral KGU6465BS REF - SXS/I&W
Admiral KGU6650 REF - SXS/I&W
Admiral KGU6651 REF - SXS/I&W
Admiral KGU6655 REF - SXS/I&W
Admiral KGU66920 REF - SXS/I&W
Admiral KGU6695 REF - SXS/I&W
Admiral KGU66990 REF - SXS/I&W
Admiral KGU6700BS REF - SXS/I&W
Admiral KGU6940BS REF - SXS/I&W
Admiral KGU6945BS REF - SXS/I&W
Whirlpool KGYE550VWH0 Residential Dryer
Whirlpool KGYE560WAL0
Whirlpool KGYE560WHT0
Whirlpool KGYE560WPL0
Whirlpool KGYE560WTO0
Whirlpool KGYE560WWH0 Residential Dryer
Whirlpool KGYE650VAL0
Whirlpool KGYE650VHT0
Whirlpool KGYE650VPL0
Whirlpool KGYE650VTO0
Whirlpool KGYE650VWH0 Residential Dryer
Whirlpool KGYE660WAL0 GAS DRYER
Whirlpool KGYE660WAL1
Whirlpool KGYE660WHT0 GAS DRYER
Whirlpool KGYE660WPL0 GAS DRYER
Whirlpool KGYE660WTO0 GAS DRYER
Whirlpool KGYE660WWH0 Residential Dryer
Whirlpool KGYE660WWH1 Residential Dryer
Whirlpool KGYE664WWH0 Residential Dryer
Whirlpool KGYE664WWH1 Residential Dryer
Whirlpool KGYE665BAL0 GAS DRYER
Whirlpool KGYE665BAL1 GAS DRYER
Whirlpool KGYE665BWH0 GAS DRYER
Whirlpool KGYE665BWH1 GAS DRYER
Whirlpool KGYE665BWH3 GAS DRYER
Whirlpool KGYE670BAL0 GAS DRYER
Whirlpool KGYE670BAL1 GAS DRYER
Whirlpool KGYE670BAL2 GAS DRYER
Whirlpool KGYE670BAL3 GAS DRYER
Whirlpool KGYE670BWH0 GAS DRYER
Whirlpool KGYE670BWH1 GAS DRYER
Whirlpool KGYE670BWH2 GAS DRYER
Whirlpool KGYE670BWH3 GAS DRYER
Whirlpool KGYE677BWH0 GAS DRYER
Whirlpool KGYE677BWH1 GAS DRYER
Whirlpool KGYE677BWH2 GAS DRYER
Whirlpool KGYE677BWH3 GAS DRYER
Whirlpool KGYE678BAL0 GAS DRYER
Whirlpool KGYE678BAL1 GAS DRYER
Whirlpool KGYE679BBL0 GAS DRYER
Whirlpool KGYE679BBL1 GAS DRYER
Whirlpool KGYE700TWH0 Residential Dryer
Whirlpool KGYE750VWH0 Residential Dryer
Whirlpool KGYE760WAL0 GAS DRYER
Whirlpool KGYE760WAL1 DRYER
Whirlpool KGYE760WHT0 GAS DRYER
Whirlpool KGYE760WPL0 GAS DRYER
Whirlpool KGYE760WTO0 GAS DRYER
Whirlpool KGYE760WWH0 Residential Dryer
Whirlpool KGYE760WWH1 Residential Dryer
Whirlpool KGYE767WWH0 Residential Dryer
Whirlpool KGYE770BAL0 GAS DRYER
Whirlpool KGYE770BAL1 GAS DRYER
Whirlpool KGYE770BAL2 GAS DRYER
Whirlpool KGYE770BWH0 GAS DRYER
Whirlpool KGYE770BWH1 GAS DRYER
Whirlpool KGYE770BWH2 GAS DRYER
Whirlpool KGYE777BWH0 GAS DRYER
Whirlpool KGYE777BWH1 GAS DRYER
Whirlpool KGYE777BWH2 GAS DRYER
Whirlpool KGYE778BAL0 GAS DRYER
Whirlpool KGYE778BAL1 GAS DRYER
Whirlpool KGYE778BAL2 GAS DRYER
KitchenAid KGYE77BWH1 GAS DRYER
Whirlpool KGYE800SWH1 Residential Dryer
Whirlpool KGYE800TAL0
Whirlpool KGYE800THT0
Whirlpool KGYE800TPL0
Whirlpool KGYE800TTO0
Whirlpool KGYE800TWH0 Residential Dryer
Whirlpool KGYE850VWH0 Residential Dryer
Whirlpool KGYE860WAL0
Whirlpool KGYE860WAL1
Whirlpool KGYE860WHT0
Whirlpool KGYE860WPL0
Whirlpool KGYE860WTO0
Whirlpool KGYE860WWH0 Residential Dryer
Whirlpool KGYE860WWH1 Residential Dryer
Whirlpool KGYE870BAL0 GAS DRYER
Whirlpool KGYE870BAL1 GAS DRYER
  #2 (permalink)
Old 06-17-2011, 03:03 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Destroyer,
The part number you'll need is:
Part number: AP3008062
And here are the excerpts from the service manual for the model number you supplied :
CAUTION:
When you work on the range, be careful when handling the sheet metal parts. Sharp edges may be present, and you can cut yourself if you are not careful.
CAUTION:
Do not lift the oven door by its handle.
REMOVING THE OVEN DOOR
1. Open the oven door to its fully open position.
2. Install a pin in the hole of each oven door hinge hanger.
3. Close the oven door as far as the two pins will allow.
4. Grasp the sides of the door and lift the door until it stops, then pull the hinge hangers out of the slots.
To reinstall the oven door:
1. Grasp the sides of the door and tilt it back at a slight angle, then insert the hinge hangers into the hinge slots as far as they will go.
2. Rotate the top of the door towards the range so the hinge hangers fit onto the support pins.
3. Close the oven door as far as the pins will allow, and make sure that the hinge hangers are fully seated on the support pins. If they are not seated properly, the door will not close tightly and may be off-center. To
seat the hinge hangers, open the door slightly, and push in on the bottom until the hangers are fully seated.
4. Open the oven door to its fully open position and remove the two hinge hanger pins.
5. Close the oven door completely and check it for proper operation and alignment.
REMOVING THE OVEN DOOR GLASS, HINGES, & HANDLE
1. Remove the oven door from the range.
2. Place the oven door on a padded work surface with the front decorative glass facing down.
3. Remove the two top door liner screws and the two door glass bracket screws, and lift the liner assembly off the decorative door glass and handle.
4.
To remove the outer door glass:
a) Remove the three outer glass holder screws and two outer glass bracket
screws from the door liner.
b) Lift the outer glass with the glass holder off the door liner.
c) Remove the bracket.
5.
To remove the center door glass,
remove the bottom bracket, (it is loose), and slide the two top corners of the glass out of the door liner slots.
6.
To remove the hinges and the inner door glass:
NOTE: You will have to remove both hinges to remove the inner door glass from the oven door liner.
a) Lift either side of the door liner, remove the two door hinge screws, and remove the hinge.
b) Lift the other side of the door liner, remove the two screws for the other
hinge, and remove the hinge.
c) Lift the inner door glass liner cover off the liner.
d) Remove the insulation and the inner door glass.
7.
To remove the door handle,
remove the two door handle screws from the bracket.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid oven inside glass replacement MarvKirsch Oven Repair (including Ranges and Cooktops) 3 08-29-2010 03:14 PM
Whirlpool Oven Inside Glass Replacement usnavyvet Oven Repair (including Ranges and Cooktops) 0 08-26-2010 09:46 AM
I need to replace inside glass on oven door stevied4 Oven Repair (including Ranges and Cooktops) 0 11-28-2009 11:47 AM
stains inside oven glass door trebby6 Oven Repair (including Ranges and Cooktops) 0 07-15-2008 01:43 PM
stains inside oven glass door trebby6 Oven Repair (including Ranges and Cooktops) 0 07-15-2008 01:42 PM
