Discuss
Whirlpool Double Wall Oven - Top Oven Not Working
 in
Recently used self-clean option on top oven and after cycle was complete I cannot get heat from either element.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Double Wall Oven - Top Oven Not Working
  #1 (permalink)
Old 11-15-2007, 09:18 AM
bigguy bigguy is offline
Junior Member
bigguy is on a distinguished road
Default Whirlpool Double Wall Oven - Top Oven Not Working
Model Number: RBD305   Brand: Whirlpool   Age: 5 - 10 years
Recently used self-clean option on top oven and after cycle was complete I cannot get heat from either element. Controls, fan and bottom oven work fine. The elements do not appear to be damaged. Based on another thread (posted on 11/1 by choldca and responded to by Gene), it appears that I will need to pull out the oven and replace a thermal fuse/thermal cut off.
Would it be possible to get instruction and part information to replace? Whirlpool Model Series #RBD305.
Please note that I already replaced the microcomputer as well because there was damage to it.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-18-2008, 07:02 AM
lavonna lavonna is offline
Junior Member
lavonna is on a distinguished road
Default
I have the exact model and same problem after running self-cleaning mode. Neither bake nor broil elements will begin to heat. Would you please share any response or how you resolved your issue if you have? Thank you!
  #3 (permalink)
Old 09-18-2008, 07:32 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Can you both post the entire model numbers off the oven themselves, so to make sure it's the same part you need. There are about 20+ RBD305 models.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #4 (permalink)
Old 09-18-2008, 08:45 AM
Junior Member
Default
My model is rbs305pdb16, I think that just means mine is a single not double oven but I know that would affect the parts. I have the same problem after self-cleaning - neither bake nor broil work but the panel works fine and the fan runs, appears to be heating but there's no heat at all.
  #5 (permalink)
Old 09-18-2008, 09:39 AM
Senior Expert
APP Volunteer
Default
lavonna,
The thermostat/TOD for your oven is part # 4451442 or AP# AP3885687
Nat
__________________
  #6 (permalink)
Old 09-18-2008, 09:53 AM
Junior Member
Default
Awesome, thank you so much! I tried to find a thermal fuse but could only find the thermostat on my model but I wasn't even sure if that would solve the problem. Thank you again!
  #7 (permalink)
Old 09-18-2008, 10:03 AM
Senior Expert
APP Volunteer
Default
Let us know if we can help with anything else.
Nat
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Double Wall Oven Warm, not Hot jcrump55 Oven Repair (including Ranges and Cooktops) 2 11-12-2007 08:36 PM
Whirlpool Double Wall oven choldca Oven Repair (including Ranges and Cooktops) 2 11-02-2007 02:02 PM
GE Electric Double Wall Oven won't bake or broil tjp Oven Repair (including Ranges and Cooktops) 0 10-27-2007 10:06 AM
Double Oven--Main oven not working bccavanaugh Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:22 PM
Whirlpool Elect Double Oven no power lfein Oven Repair (including Ranges and Cooktops) 1 09-12-2007 11:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
