Oven and broiler shows F3 error code after setting temp. Two digit F3 code consistent with temperature sensor failure. Is there something else to check or should I replace sensor. I note that sensor wire goes through hole to back of oven. How do I unplug the connection and replace the sensor? Do I need to access the back of oven and can this be done from inside oven? Thanks.
