| » bake glows, not ignite, broiler works fine |
Model Number: FGF379WECT Brand: Frigidaire Age: 5 - 10 years
Bake igniter glows brightly, but does not ignite after 60 seconds. Broiler works fine, surface burners work fine. Bake igniter has small whitish area, but no gaps.
Most likely the problem is a bad igniter. The current in the line is not enough to open the gas valve.
- The part number for the oven igniter AP2150412 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
only thing left is the gas valve and also the igniter should be reading 3-4 amps to kick on the gas vavle if you want to go at it another way put meter leads on the gas valve watch for voltage to appear if it does and still no ignition for sure gas valve it may be possible for the regulator to be bad on one side maybe
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas |
| Display Modes | |
| Kenmore front loader washer works fine but does not spin | busted | Washer Repair | 7 | 11-01-2008 01:11 PM |
| Roper gas oven will not ignite but pilot works | rick anderson | Oven Repair (including Ranges and Cooktops) | 0 | 11-01-2007 08:47 AM |
| Whirlpool Oven won't heat stove works fine | tnearman | Oven Repair (including Ranges and Cooktops) | 2 | 10-18-2007 10:13 AM |
| Freezer works fine but refrigerator does not hold temperature | mikel500 | Refrigerator & Freezer Repair | 0 | 10-16-2007 06:57 AM |
| Igniter glows but no flame. | zab | Dryer Repair | 1 | 08-06-2007 07:55 PM |
