Discuss
Thermadore Range Display and Oven Problem
 in
Hi, We had a power surge today as a result of a winter storm (I was watching TV and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermadore Range Display and Oven Problem
  #1 (permalink)
Old 03-01-2009, 03:34 PM
Junior Member
mars315 is on a distinguished road
Default Thermadore Range Display and Oven Problem
Model Number: RDDS30V   Brand: Thermador   Age: 5 - 10 years
We had a power surge today as a result of a winter storm (I was watching TV and the TV and the lights kind of dimmed a couple of times, making the TV go off once). When I went to check if any of my digital clocks in the kitchen needed to be reset, I discovered that the display to my Thermadore range was completely blank. The stove-top (Gas) works, and so does the pop-up vent (electric). Also, the light INSIDE of the oven works. Also, if I press the button for either "convection" or "bake" I hear a "click" which it normally does when it is turning on, but then it quickly "clicks" again when it can see that it is not about to get any power. We did try resetting the breaker, but unfortunately that was not the answer. Clearly, something controlling both the display panel and the oven going on was ruined (or maybe two somethings). Once before on my Thermador wall oven, after a self-clean the control panel was fried and I was able to order one online and replace it myself. Hopefully someone knows what we can do to fix our range this time.
I did more research and I think it might be the "Control Unit." Anyone know if this is right and if I can replace this myself?
Thanks, Michelle
Ads By Google
Related Models
Thermador RDDS30V
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Whirlpool RDE1100W0
Whirlpool RDE1100W1
Whirlpool RDE1100W2
Whirlpool RDE1300W
Whirlpool RDE1300W1
Whirlpool RDE1300W2
Whirlpool RDE1400W
Whirlpool RDE1400W1
Whirlpool RDE1400W2
Whirlpool RDE22302
Whirlpool RDE2300W
Whirlpool RDE2300W1
Whirlpool RDE2300W2
Whirlpool RDE2400P0
Whirlpool RDE2400P1
Whirlpool RDE2400P2
Whirlpool RDE2400W0
Whirlpool RDE2400W1
Whirlpool RDE2400W2
Whirlpool RDE2500P0
Whirlpool RDE2500P1
Whirlpool RDE2500P2
Whirlpool RDE3000W
Whirlpool RDE3020W
Whirlpool RDE3100W
Whirlpool RDE31E0W
Whirlpool RDE32302
Whirlpool RDE3230W
Whirlpool RDE3300W
Whirlpool RDE3340W
Whirlpool RDE3360W
Whirlpool RDE3400W
Whirlpool RDE3400W1
Whirlpool RDE3400W2
Whirlpool RDE3450W
Whirlpool RDE34EPW
Whirlpool RDE350PW
Whirlpool RDE350PW1
Whirlpool RDE355PP
Whirlpool RDE3600W
Whirlpool RDE3600W2
Whirlpool RDE3700W
Whirlpool RDE3700W1
Whirlpool RDE3700W2
Whirlpool RDE3900W
Whirlpool RDE3900W1
Whirlpool RDE390PW
Whirlpool RDE390PW2
Whirlpool RDE3950W
Whirlpool RDE395PP
Whirlpool RDE4400W0
Whirlpool RDE4400W1
Whirlpool RDE4400W2
Whirlpool RDE4900W
Whirlpool RDE4900W1
Whirlpool RDE4900W2
Whirlpool RDE4950W
Whirlpool RDE6030W0
Whirlpool RDE6030W1
Whirlpool RDE6030W2
Whirlpool RDE6030W3
Whirlpool RDE6100W
Whirlpool RDE6100W1
Whirlpool RDE6100W2
Whirlpool RDE6300W
Whirlpool RDE6300W1
Whirlpool RDE6300W2
Whirlpool RDE630PN0
Whirlpool RDE6550W
Whirlpool RDE6550W1
Whirlpool RDE6550W2
Whirlpool RDE6700W
Whirlpool RDE6700W1
Whirlpool RDE6700W2
Whirlpool RDE8400W
Whirlpool RDE8400W1
Whirlpool RDE8400W2
Whirlpool RDE8500W
Whirlpool RDE8500W1
Whirlpool RDE8500W2
Whirlpool RDE8550
Whirlpool RDE85501
Whirlpool RDE85502
Whirlpool RDE950PW
Whirlpool RDE950PW1
Whirlpool RDE950PW2
Whirlpool RDE955PP
Whirlpool RDE9600W
Whirlpool RDE9600W2
Thermador RDF30
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Whirlpool RDH2030
Whirlpool RDH2036
Whirlpool RDH2330
Whirlpool RDH2336
Whirlpool RDH2630
Whirlpool RDH2636
Whirlpool RDH4330
Whirlpool RDH4336
Whirlpool RDH4630
Whirlpool RDH4636
Whirlpool RDH7330
Whirlpool RDH7336
Whirlpool RDH7630
Whirlpool RDH7636
Whirlpool RDH8330
Whirlpool RDH8630
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven Control Panel Display Problem rr2009 Oven Repair (including Ranges and Cooktops) 0 12-27-2009 09:27 PM
Display panel out and oven does not go on..Is this a fuse problem? mbsrfnusa Oven Repair (including Ranges and Cooktops) 0 09-06-2009 01:07 PM
Oven Control Display Problem scottishlad Oven Repair (including Ranges and Cooktops) 0 08-02-2009 07:24 AM
Drop-In Range Display Wacky, Oven & Broiler Don't Work mydogsmom Oven Repair (including Ranges and Cooktops) 3 06-05-2009 11:28 PM
No display on oven/range control board jeangarcia Oven Repair (including Ranges and Cooktops) 1 12-01-2008 05:30 PM
