Old control replaced by WP27T10287. My questions:
1.It looks like I need to cut the wires as the plastic protective sleeves will not fit on the new control. Is this OK?
2. J4 pin connection has 7 pins (2 on left 5 on right) and the old control only has 5 (2 on left and 3 on right) -- do I connect to the common 2 and leave extra 2 exposed?
3. Any other help on installing this would be appreciated as the instructions are less than clear.
Thank you,
JohnnineS
