| » Fred Maringer |
Model Number: MGS5770ADW Brand: Maytag Age: 5 - 10 years
The oven does not keep the correct tempurture. I have replaced the sensor which did not correct the problem. My question is there anything I should look at before replacing the oven control board.(P/N AP4096970 Clock & Display) Any help will be greatly appreicated. Thanks for your help. Fred
Related Models |
When you say not keeping the correct temperature, is it off by a consistent value, or does it seem to work for awhile then cool off? If it is off consistently, you could replace the control, or first try adjusting the temperature offset as described in the use and care guide. Some times the electronics will drift a bit so the offsets are put in place allowing the user to make adjustments. Now if it seems to take twice as long to bake something, then there may be something else we need to take a look at.
More information. When I replaced the sensor the oven was about 50 degrees off. I tried to adjust it using the control panel. I increased it to the max which is 35 degrees. the same problem exists. One time too hot and the next time not hot enough. It also appears that the cooling fan does not always work. I'm notsure when it should turn on. It does go on when you set the over to broil.
Thanks Fred |
| Display Modes | |
| Fred | frednk | Oven Repair (including Ranges and Cooktops) | 7 | 12-09-2009 07:08 PM |
| Fred | wilkerson | Dishwasher Repair | 1 | 11-19-2007 01:58 PM |
