Discuss
Whirlpool oven ctrl panel
 in
The control panel of my Whirlpool Oven seems dead suddenly. It displays PF and time, but there is not response
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven ctrl panel
  #1 (permalink)
Old 11-14-2007, 10:46 AM
johnli johnli is offline
Junior Member
johnli is on a distinguished road
Question Whirlpool oven ctrl panel
Model Number: GW395LEPS00   Brand: Whirlpool   Age: 1 - 5 years
The control panel of my Whirlpool Oven seems dead suddenly. It displays PF and time, but there is not response to my input anymore. the oven light functions when the door is open. Do I have to replace the control panel and where to get it in Vancouver? Any help or informations will be highly appreciated!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-14-2007, 03:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is reset the power to the range. Unplug it for a few minutes and then plug it back. Sometimes it helps to eliminate the problem.
The next step check the range for the proper grounding.
If it would not help then the control panel has to be replaced.
Unfortunately the AppliancePartsPros.com does not ship parts outside of USA.
If you have any shipping address within USA they will be glad to help you with the part. In that case I need the color of the control panel.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-14-2007, 03:35 PM
Junior Member
Thumbs up
Thank you so much for your kindly help.
I have already tried the first method, it did not solve my problem. I am not good at electrical stuff, could you please tell me how to check the proper grounding? Do I need a versatile meter or sth?
my ctrl panel is the stainless steel color, is it in stock now?
  #4 (permalink)
Old 11-14-2007, 04:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to do it you need just a simple meter.
The power between the hot and the ground should be 120V and between the hot and the neutral it should be 120V. It suppose to be close to 0 Ohms between the neutral and the ground. The ground wire from the power cord should be connected to the range frame.
If you got all of these readings right, then the range is grounded properly.
- The part number for the control panel AP4263578 and it is in stock.
__________________
  #5 (permalink)
Old 11-14-2007, 05:27 PM
Junior Member
Default
Thanks, Gene. I will try this grounding thing first.
Jun
  #6 (permalink)
Old 11-20-2007, 02:45 PM
onegumshoe onegumshoe is offline
Junior Member
onegumshoe is on a distinguished road
Default Same Problem...
Hi...
I read your description of the problem and my controls (same model oven) suddenly do not operate the oven. Some beep...some don't... but only a few actually work. Did you ever solve yours and if so...what was it? The control panel or the circuit board? Thanks for any help...
  #7 (permalink)
Old 11-20-2007, 02:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to provide the most accurate advise I need the complete model number of the oven and full description of the problem.
Post it as a new thread, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing oven control panel brad Oven Repair (including Ranges and Cooktops) 2 07-14-2008 03:55 PM
whirlpool oven Gallo Oven Repair (including Ranges and Cooktops) 3 11-09-2007 01:17 PM
Whirlpool Gas Oven Bayardo Oven Repair (including Ranges and Cooktops) 1 11-05-2007 07:34 PM
Need help with Whirlpool oven Kristie Oven Repair (including Ranges and Cooktops) 1 10-16-2007 12:09 PM
Question about replacing an oven control panel Arnheimacres Oven Repair (including Ranges and Cooktops) 0 10-02-2007 07:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
