This oven was working fine then made a loud "POP" sound. The breaker tripped and was reset. The main digital display still works and appears with the temp numbers when setting the temp for the oven but the elements in the oven do not get hot (elements test as fine). All other functions work There are two boards in the back (1) behind the digital display and keyboard (2) slightly smaller board and mounted about 18" away lower left side (looking form back) I would appreciate any help as to knowing just what to replace to correct this problem. Thank You
