Discuss
Whirlpool Oven code F3
 in
I have a Whirlpool Oven Model# RBS245PDB8, Serial# XK0901030 Using the oven at 425 degrees and the timer was set
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Oven code F3
  #1 (permalink)
Old 02-27-2009, 09:25 AM
cdrisdale cdrisdale is offline
Junior Member
cdrisdale is on a distinguished road
Default Whirlpool Oven code F3
Model Number: RBS245PDB8   Brand: Whirlpool   Age: 5 - 10 years
Using the oven at 425 degrees and the timer was set for 45 minutes, During the cooking time with 18 minutes left, I heard a click and noticed the control panel said "F 3 locked". I couldn't open the door since it was locked. I tried to cancel and it wouldn't work. We had to turn the breaker switch off to turn the oven off. Once the oven cooled down we swtiched the breaker back on and the oven unlocked. A couple days later I tried to use the oven again. The control panel works fine but the oven will not heat up now. Both elements, the broiler and the bake will not heat up. I had the elements checked out and both are fine. Help Please.
Related Models
Whirlpool RBS245PDB8
Whirlpool RBS245PDB9
Whirlpool RBS245PDQ1
Whirlpool RBS245PDQ10
Whirlpool RBS245PDQ11
Whirlpool RBS245PDQ12
Whirlpool RBS245PDQ13
Whirlpool RBS245PDQ14
Whirlpool RBS245PDQ15 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDQ16 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDQ18 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDQ2
Whirlpool RBS245PDQ4
Whirlpool RBS245PDQ6
Whirlpool RBS245PDQ8
Whirlpool RBS245PDQ9
Whirlpool RBS245PDS12
Whirlpool RBS245PDS14
Whirlpool RBS245PDS15 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDS16 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDS17 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDS18 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDT10
Whirlpool RBS245PDT11
Whirlpool RBS245PDT12
Whirlpool RBS245PDT13
Whirlpool RBS245PDT14
Whirlpool RBS245PDT15 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDT16 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDT18 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PDT8
Whirlpool RBS245PDT9
Whirlpool RBS245PRB00 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PRQ00 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PRS00 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS245PRT00 24" Built - in Electric Single Oven Self - Clean
Whirlpool RBS270PDB1
Whirlpool RBS270PDB3
Whirlpool RBS270PDB4
Whirlpool RBS275PDB1
Whirlpool RBS275PDB10
Whirlpool RBS275PDB11
Whirlpool RBS275PDB12
Whirlpool RBS275PDB13
Whirlpool RBS275PDB14
Whirlpool RBS275PDB16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDB17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDB2
Whirlpool RBS275PDB4
Whirlpool RBS275PDB6
Whirlpool RBS275PDB8
Whirlpool RBS275PDQ1
Whirlpool RBS275PDQ10
Whirlpool RBS275PDQ11
Whirlpool RBS275PDQ12
Whirlpool RBS275PDQ13
Whirlpool RBS275PDQ14
Whirlpool RBS275PDQ16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDQ2
Whirlpool RBS275PDQ4
Whirlpool RBS275PDQ6
Whirlpool RBS275PDQ8
Whirlpool RBS275PDS12
Whirlpool RBS275PDS14
Whirlpool RBS275PDS16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDS17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT10
Whirlpool RBS275PDT11
Whirlpool RBS275PDT12
Whirlpool RBS275PDT13
Whirlpool RBS275PDT14
Whirlpool RBS275PDT16 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PDT17 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRB00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRQ00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRS00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS275PRT00 27" Built - in Electric Single Oven Self - Clean
Whirlpool RBS277PDB1
Whirlpool RBS277PDB2
Whirlpool RBS277PDB4
Whirlpool RBS277PDQ1
Whirlpool RBS277PDQ2
Whirlpool RBS277PDQ4
Whirlpool RBS305PDB1
Whirlpool RBS305PDB10
Whirlpool RBS305PDB11
Whirlpool RBS305PDB12
Whirlpool RBS305PDB13
Whirlpool RBS305PDB14
Whirlpool RBS305PDB16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDB2
Whirlpool RBS305PDB4
Whirlpool RBS305PDB6
Whirlpool RBS305PDB8
Whirlpool RBS305PDB9
Whirlpool RBS305PDQ1
Whirlpool RBS305PDQ10
Whirlpool RBS305PDQ11
Whirlpool RBS305PDQ12
Whirlpool RBS305PDQ13
Whirlpool RBS305PDQ14
Whirlpool RBS305PDQ16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDQ2
Whirlpool RBS305PDQ4
Whirlpool RBS305PDQ6
Whirlpool RBS305PDQ8
Whirlpool RBS305PDQ9
Whirlpool RBS305PDS12
Whirlpool RBS305PDS14
Whirlpool RBS305PDS16 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDS17 30" Built - in Electric Oven Self Clean
Whirlpool RBS305PDT10
Whirlpool RBS305PDT11
Whirlpool RBS305PDT12
Whirlpool RBS305PDT13
Whirlpool RBS305PDT14
Whirlpool RBS305PDT16 30" Built - in Electric Oven Self Clean
  #2 (permalink)
Old 02-27-2009, 04:24 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
To start with the F3 is a temperature error as you might have guessed and basically what happened was the electronic control sensed a higher than expected temperature and locked the door for safety. As long as the temperature remains high, the door will remain locked and nothing except cycling the power will unlock the door. The temperature must have been pretty high because if both elements no longer work, most likely your thermal overload (AP3885687) located on the back of the oven has opened the circuit and now needs to be replaced. While you are back there, you can check the oven sensor operation by taking a resistance reading at the connector (the one with the violet wires attached) and see if you about 1080 ohms at room temperature. Way high or way low, then it needs to be replaced.
As for the reason this happened, either the temperature sensor was giving high readings to the control board, or a relay on the control board kept one of the element on the entire time instead of cycling as it should. My guess is the sensor is fine since the open thermal overload is a good indication it really was hot inside the oven. So that would leave the oven control. You may be able to replace the overload and have it work just fine. But I would keep an eye on it during the short term and verify you hear the normal clicking coming from the control board while you are cooking. If it runs away again, shut off the power at the breaker and replace the control board (AP3177932).
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dbl Oven E6 F2 code themalones1995@gmail.com Oven Repair (including Ranges and Cooktops) 0 12-31-2009 07:18 AM
Whirlpool Dbl Oven E6 F2 code themalones1995@gmail.com Oven Repair (including Ranges and Cooktops) 1 12-29-2009 02:05 PM
E6 F2 Code on Whirlpool Oven sonny9 Oven Repair (including Ranges and Cooktops) 1 12-24-2008 11:56 AM
Whirlpool Oven error code E3 F1 Alamo1 Oven Repair (including Ranges and Cooktops) 0 06-12-2008 04:16 PM
F3 Code Whirlpool Oven hershey968 Oven Repair (including Ranges and Cooktops) 0 06-04-2008 08:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
