I need parts for a frigidaire free standing oven (model #PLEFM399DCB). The bake element went bad and also supposedly fried some circuits (they initially replaced the element and it still would not work). Everything else on the oven works (stove top and the mini-oven), including the electronic oven controls. I assume the circuits they are referring to are in the power board. Does that sound right?
If it is only the bake element that has failed, then you need a new oven control ( AP3776965) as that is what powers the bake and broil element. The power board is for the surface units so if they are working, that board if fine.
