Discuss
Jenn-Air front right dual element won't back off high
 in
Hi, We have a electric cooktop range that is having an issue where the front right element only heats to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air front right dual element won't back off high
  #1 (permalink)
Old 02-26-2009, 09:36 AM
nujer nujer is offline
Junior Member
nujer is on a distinguished road
Default Jenn-Air front right dual element won't back off high
Model Number: JER8855BAS   Brand: Jenn-Air   Age: 5 - 10 years
We have a electric cooktop range that is having an issue where the front right element only heats to a high level and will not back down when a lower level of heat is dialed in. This element is different than the other three in that it is a dual function element that heats an inner/outer coils.
I believe the control switch for this element is bad, but am confused with what I need to order. Is it an infinite switch or control switch? Are these referring to the same part? I found a part listed here that is called a dual element switch and I'm guessing that is what I need but I'd like to see if anyone has an opinion before I order it.
Thanks.
Related Models
Jenn-Air JER8855BAS Range - F/s Std Ele
Jenn-Air JER8885QAB Range - F/s Std Ele
Jenn-Air JER8885QAF Range - F/s Std Ele
Jenn-Air JER8885QAS Range - F/s Std Ele
Jenn-Air JER8885QCB Range - F/s Std Ele
Jenn-Air JER8885QCF Range - F/s Std Ele
Jenn-Air JER8885QCS Range - F/s Std Ele
Jenn-Air JER8885RAB Range - S/c F/s Ele
Jenn-Air JER8885RAF Range - S/c F/s Ele
Jenn-Air JER8885RAS Range - S/c F/s Ele
General Electric JES0601T01
General Electric JES0601T010 Counter top microwave
General Electric JES0601T011 Counter top microwave
General Electric JES0601T012 Counter top microwave
General Electric JES0601T02 Counter top microwave
General Electric JES0601T03 Counter top microwave
General Electric JES1022TW01 Counter top microwave
General Electric JES1022TW02 Counter top microwave
General Electric JES1022TW03 Counter top microwave
General Electric JES1022TW04 Counter top microwave
General Electric JES1030TP01 Counter top microwave
General Electric JES1030TW01 Counter top microwave
General Electric JES1030TW02 Counter top microwave
General Electric JES1031TW01 Counter top microwave
General Electric JES1031TW02 Counter top microwave
General Electric JES1033BA01 Counter top microwave
General Electric JES1033BB01 Counter top microwave
General Electric JES1033WA01 Counter top microwave
General Electric JES1033WB01 Counter top microwave
General Electric JES1034WF001 Counter top microwave
General Electric JES1034WF02 Counter top microwave
General Electric JES1036BK01 Counter top microwave
General Electric JES1036NL01 Counter top microwave
General Electric JES1036PWF001 Counter top microwave
General Electric JES1036PWH001 Counter top microwave
General Electric JES1036PWH002 Counter top microwave
General Electric JES1036PWH03 Counter top microwave
General Electric JES1036WF001 Counter top microwave
General Electric JES1036WF002 Counter top microwave
General Electric JES1036WF03 Counter top microwave
General Electric JES1036WK01 Counter top microwave
General Electric JES1036WK02 Counter top microwave
General Electric JES1039BJ01 Counter top microwave
General Electric JES1039BJ02 Counter top microwave
General Electric JES1039WF001 Counter top microwave
General Electric JES1039WJ01 Counter top microwave
General Electric JES1039WJ02 Counter top microwave
General Electric JES1131GB002 Counter top microwave
General Electric JES1131GB01 Counter top microwave
General Electric JES1131WC002 Counter top microwave
General Electric JES1133PN01 Counter top microwave
General Electric JES1133PN02 Counter top microwave
General Electric JES1133PN03 Counter top microwave
General Electric JES1133WD01 Counter top microwave
General Electric JES1133WN01 Counter top microwave
General Electric JES1133WN02 Counter top microwave
General Electric JES1133WN03 Counter top microwave
General Electric JES1133WN04 Counter top microwave
General Electric JES1133WN05 Counter top microwave
General Electric JES1133WN06 Counter top microwave
General Electric JES1133WNP01 Counter top microwave
General Electric JES1133WNP02 Counter top microwave
General Electric JES1133WNP03 Counter top microwave
General Electric JES1134WN01 Counter top microwave
General Electric JES1134WN02 Counter top microwave
General Electric JES1134WN03 Counter top microwave
General Electric JES1134WN04 Counter top microwave
General Electric JES1136WK01 Counter top microwave
General Electric JES1136WL01 Counter top microwave
General Electric JES1139BL01 Counter top microwave
General Electric JES1139WL01 Counter top microwave
General Electric JES1142SF001 Counter top microwave
General Electric JES1142SF02 Counter top microwave
General Electric JES1142SJ01 Counter top microwave
General Electric JES1142SJ02 Counter top microwave
General Electric JES1142SJ03 Counter top microwave
General Electric JES1142SJ04 Counter top microwave
General Electric JES1142WD001 Counter top microwave
General Electric JES1142WD02 Counter top microwave
General Electric JES1142WD03 Counter top microwave
General Electric JES1142WD04 Counter top microwave
General Electric JES1143WW01 Counter top microwave
General Electric JES1143WW02 Counter top microwave
General Electric JES1143WWP01 Counter top microwave
General Electric JES1144WY01 Counter top microwave
General Electric JES1144WY02 Counter top microwave
General Electric JES1144WY03 Counter top microwave
General Electric JES1144WYP01 Counter top microwave
General Electric JES1146BF001 Counter top microwave
General Electric JES1146BF002 Counter top microwave
General Electric JES1222T01 Counter top microwave
General Electric JES1224T01 Counter top microwave
General Electric JES1224T02 Counter top microwave
General Electric JES1231WC001 Counter top microwave
General Electric JES1231WD001 Counter top microwave
General Electric JES1231WD002 Counter top microwave
General Electric JES1235BF001 Counter top microwave
General Electric JES1235WF001 Counter top microwave
General Electric JES1238WH001 Counter top microwave
General Electric JES1238WH002 Counter top microwave
General Electric JES1238WH03 Counter top microwave
General Electric JES1243GA01 Counter top microwave
General Electric JES1244GB001 Counter top microwave
General Electric JES1244GC001 Counter top microwave
General Electric JES1244WA01 Counter top microwave
General Electric JES1244WC001 Counter top microwave
General Electric JES1246BH001 Counter top microwave
General Electric JES1246BH002 Counter top microwave
General Electric JES1246BH01 Counter top microwave
General Electric JES1246BH03 Counter top microwave
General Electric JES1246WH001 Counter top microwave
General Electric JES1246WH002 Counter top microwave
General Electric JES1246WH01 Counter top microwave
General Electric JES1246WH03 Counter top microwave
General Electric JES1288SH001 Counter top microwave
General Electric JES1288SH02 Counter top microwave
General Electric JES1288SH03 Counter top microwave
General Electric JES1289SK01 Counter top microwave
General Electric JES1289SK02 Counter top microwave
General Electric JES1290BJ01 Counter top microwave
  #2 (permalink)
Old 02-26-2009, 12:58 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
The dual element switch (AP4096023) would be the correct part. The switch is stuck in the high position and needs to be replaced. Pay attention to the wire placement on the existing switch when doing the replacement. The new switch may look different than the original and may come with a set of instructions to properly wire it in.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-26-2009, 01:12 PM
Junior Member
Default
Thanks Brian. I will give replacing that part a shot and will post the result.
Much appreciated!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-air cooktop dual element wporter Oven Repair (including Ranges and Cooktops) 1 12-29-2009 12:18 PM
jenn air dual element does not heat ajax5777 Oven Repair (including Ranges and Cooktops) 1 06-28-2009 01:23 PM
Whirlpool Accubake dual oven--wont come back on bjersfamily Oven Repair (including Ranges and Cooktops) 1 01-28-2009 03:24 PM
dual element stuck on high hi-ranger Oven Repair (including Ranges and Cooktops) 1 12-12-2008 04:02 PM
Cooktop dual element only runs on HIGH heat Sevvy Oven Repair (including Ranges and Cooktops) 0 07-20-2008 02:18 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
